> Engine Cooling Fan Stuck?
didenpx
post Nov 16 2025, 03:08 PM
I have my engine out (75 1.8 fwiw) and am trying to remove the cooling fan with no luck. I have a puller and it doesn’t budge, but I also was conservative on torquing because I’m afraid of stripping threads. Is there some hidden trick to this? I’ve got the hub basting in PB Blaster while I consult you gurus.
TIA
Paul
Replies(1 - 3)
930cabman
post Nov 16 2025, 05:03 PM
can you put some heat on the aluminum hub prior to attaching the puller?
burton73
post Nov 16 2025, 05:13 PM
Senior member, and old dude
When you put a lot of penetrating oil or product on. Tap it with a mallet to try to get it too let it get in. They can be very stuck. It takes time but it will work after a while
Bob B
didenpx
post Nov 16 2025, 05:43 PM
Thanks; I will add heat and tapping to the routine.
2 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
1 Members: Jack Standz
- Lo-Fi Version Time is now: 17th November 2025 - 07:04 PM
