| maxwelj |
Nov 21 2025, 10:21 AM
rebuilt member ![]() ![]() Group: Benefactors Posts: 290 Joined: 8-January 04 From: Owasso, OK Member No.: 1,532 Region Association: None
A question for the experts here(or anyone who knows the answer).. how do these pieces attach to the steering column/ clamshell? Do they just slide in ? I can’t seem to make them stay. 70 914/6.
Attached thumbnail(s) |
| tygaboy |
Nov 21 2025, 10:30 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,803 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California
Sorry I can't help with the "how". But I need a set of those. Are yours factory or did you find them reproduced? And if repro, where? Thanks for any help.
| IronHillRestorations |
Nov 21 2025, 10:38 AM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,926 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
They should have a slot at the base that slides into the dash face
| maxwelj |
Nov 21 2025, 11:29 AM
| maxwelj |
Nov 21 2025, 02:42 PM
| mb911 |
Nov 21 2025, 03:26 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,728 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
Sorry I can't help with the "how". But I need a set of those. Are yours factory or did you find them reproduced? And if repro, where? Thanks for any help. I bought some very rough 3d printed ones from auto Atlanta. I do think a good 3d print of these would sell well |
| rgalla9146 |
Nov 21 2025, 09:13 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,950 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
| mepstein |
Nov 22 2025, 05:07 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Who sells 914-6 dash face tins?
I need a set as well as the clamshells. |
| rgalla9146 |
Nov 22 2025, 07:06 AM
Who sells 914-6 dash face tins? I need a set as well as the clamshells. I can't believe this but of all things Summit Racing sells the clamshells. Credit to Chris (tygaboy) for finding this. I'm curious to hear about quality. The price is ... $51 each piece or for both ? The tins ? I used sections of four cylinder dash tins modified and patched (welded ? ...can't remember) to suit. Attached thumbnail(s) |
| rgalla9146 |
Nov 22 2025, 07:08 AM
backside slots Attached thumbnail(s) |
| mepstein |
Nov 22 2025, 09:20 AM
Rory - Do you have a part number. My search skills are letting me down. Chances are Summit sells it because one of the big distributors like SSF or Worldpac sells it. If I have a part number I can see if any of the big guys sell it. Thanks
@rgalla9146 never mind - part #91455224110 Can't find anyone who's actually stocking it. |
| tygaboy |
Nov 22 2025, 09:55 AM
From my Summit order. The quality is great, fit is great. I couldn't be happier.
| tygaboy |
Nov 22 2025, 10:04 AM
Heads up that in order to fit the lower dash pad, there's that little edge I had to trim off. It's on the lower shell and essentially hidden when everything's installed.
Hope this helps. Attached image(s)
| rgalla9146 |
Nov 22 2025, 12:12 PM
So ... The parts are ~ $52 each ? Top and bottom are sold seperate for total of $100. + ? |
| tygaboy |
Nov 22 2025, 12:18 PM
So ... The parts are ~ $52 each ? Top and bottom are sold seperate for total of $100. + ? @rgalla9146 Yep. $105 for the set. Well under 1/2 price vs Porsche. Plus, it's from Summit so returnable, for essentially any reason. I figured it was low risk so went for it. Again, great result, buy with confidence! |
| JamesM |
Nov 22 2025, 01:01 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,187 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Sorry I can't help with the "how". But I need a set of those. Are yours factory or did you find them reproduced? And if repro, where? Thanks for any help. These are OEM , I think. Came with the car. Be very careful with those as reproductions are currently not available. I have been seeking a set for a customer car for 6 months now. and to answer your question, they don't mount to the clamshell, they sit behind it. There is a channel that slides into the dash facia pieces on both sides. Easier to install if you haven't already installed the facia and steering column. |
| JamesM |
Nov 22 2025, 01:03 PM
| JamesM |
Nov 22 2025, 01:10 PM
I can't believe this but of all things Summit Racing sells the clamshells. That is not the correct clamshell for a 914-6. It will work but it is physically different. 914 613 311 00 is the correct column cover/switch housing and 914 552 241 10 are the pieces that you have in your photo Autoatlanta had someone that was molding reproductions but they no longer are. We have been working to try and facilitate production as we have a factory -6 in need but as of right now there is no ETA (and there may never be) That said if you are happy with the 911 bits we will take those pieces off your hands as we have a build needing them. |
| rudedude |
Nov 22 2025, 05:11 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 555 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest
I have the dash face tins off my /6 to recover if anyone wants the dimensions or a trace of it
| rgalla9146 |
Nov 22 2025, 05:53 PM
I have the dash face tins off my /6 to recover if anyone wants the dimensions or a trace of it That's a generous offer. I modified/frabricated from scratch to avoid dissasembling my original 6 dash to simply trace the original 6 shape. If you're determined to do it as original this is a time saver. The opposite of rude. Big props. |
Lo-Fi Version | Time is now: 1st April 2026 - 10:21 PM |
