| HLANG |
Nov 26 2025, 08:56 AM
Newbie ![]() Group: Members Posts: 1 Joined: 15-August 25 From: Germany Member No.: 28,926 Region Association: Germany |
I just recently did a complete 2L engine overhaul and installed forged JE-Pistons with Biral Cylinder Liner kit 96 mm bore. The compression is fine, the engine runs well but I experience a consumption of 1 liter oil per 1.000 Km. After I checked the combustion chamber I found too much oil deposits on the spark plugs and the pistons. The ring gap of the piston rings is in tolerance so I wonder why there still passes so much oil from the crankcase into the combustion chamber.
| Superhawk996 |
Nov 26 2025, 09:28 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,539 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Without knowing details of how you broke the engine in, the mileage on it, and/or whether you are running a functional thermostat and cooling flaps it’s hard to say what’s going on.
Whether or not you are running fuel injection or carbs (and their tuning) also plays a part in whether or not the cylinder walls are washed down leading to crazy ring wear or failure to seat the rings. However that isn’t excessive oil consumption by the factory manual. Yes it’s more than a modern engine but it isn’t excessive. It’s more than I would want to see on a fresh rebuild. However, if your mileage is low and the rings haven’t seated fully, it will probably decrease with more mileage as the rings seat. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 26th November 2025 - 10:36 AM |
