| Mitox |
Nov 28 2025, 03:25 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 538 Joined: 26-October 15 From: SW Virginia Member No.: 19,302 Region Association: South East States
This kit from JBugs looks like it would work on the 914. Maybe?
The sale Price looks good also. https://www.jbugs.com/product/16-2236.html VW 930 Axle Kit - 20 1/4" - with 28 Spline Axles |
| 914Sixer |
Nov 28 2025, 05:28 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,453 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Yes it will work IF you have flanges and stub axles. Says they are BACKORDERED.
| Mitox |
Nov 28 2025, 05:33 PM
| mb911 |
Nov 28 2025, 07:18 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,728 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
Mine are full floating and came from PMB
| bdstone914 |
Nov 28 2025, 08:10 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,280 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
This kit from JBugs looks like it would work on the 914. Maybe? The sale Price looks good also. https://www.jbugs.com/product/16-2236.html VW 930 Axle Kit - 20 1/4" - with 28 Spline Axles ![]() 914 CVs use two 10mm roll pins. Those are VW CVs with 6 bolts. I would drill two of the holes to 10mm ans install roll pins. Not sure about the axle lenght as VW bug axles are shorter |
| bdstone914 |
Nov 28 2025, 08:13 PM
Yes it will work. Says they are BACKORDERED. I didn’t see the back order status - hopefully they would honor the pricing. Attached thumbnail(s) |
| 914Sixer |
Nov 28 2025, 08:43 PM
Corrected my yes statement. You need 911 hubs and stubs to make them work. Add about $1k for them.
| Jack Standz |
Nov 29 2025, 04:23 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 743 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Correct my yes statement. You need 911 hubs and stubs to make them work. Add about $1k for them. If you have the 911 stubs and hubs along with the 108mm flanges on the transmission side (the same parts you will need for those $595 axles), these will work and are only $30 per axle: https://www.rockauto.com/en/moreinfo.php?pk...288&jsn=475 Here's further discussion on the subject: http://www.914world.com/bbs2/index.php?sho...=368822&hl= This also means you'll need 5 bolt wheels, as the 28 spline hubs only come for the five lugs. |
| Mitox |
Nov 29 2025, 01:59 PM
Correct my yes statement. You need 911 hubs and stubs to make them work. Add about $1k for them. If you have the 911 stubs and hubs along with the 108mm flanges on the transmission side (the same parts you will need for those $595 axles), these will work and are only $30 per axle: https://www.rockauto.com/en/moreinfo.php?pk...288&jsn=475 Here's further discussion on the subject: http://www.914world.com/bbs2/index.php?sho...=368822&hl= This also means you'll need 5 bolt wheels, as the 28 spline hubs only come for the five lugs. Thanks for the links - I haven’t read these threads before |
| Maltese Falcon |
Nov 29 2025, 02:36 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,209 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Also source or machine 4) 10mm stainless/ or cold-roll short dowels >>needed for 2)left 2)right dowel pins at the outboard (trailing arm) sides of this axle set up (blue stripe indicated).
10mm (10.9) grade bolts, and 10mm Schnoor washers work well. No gaskets available for c/v's...so thin film of silicon permatex to make the seal. (IMG:style_emoticons/default/marty914.jpg) |
| Jack Standz |
Nov 29 2025, 04:10 PM
Yes, you will need roll pins. Here's one source:
https://www.pelicanparts.com/More_Info/9990...-095-019-00-OEM Rock Auto did provide fasteners with the axles, but can't remember if they provided schnoor washers. |
| Steve |
Nov 30 2025, 12:13 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,028 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
Swayaway axles part number 2420 20.25” custom 930 axles
Are the ones I’m using. 108mm 915 trans flanges and early 911 1973 stub axles with floating 108mm cv’s. |
Lo-Fi Version | Time is now: 1st April 2026 - 04:44 PM |
