> Front A arm bushing question
rick 918-S
post Nov 30 2025, 11:07 AM
Hey nice rack! -Celette
I am installing new front bushings on the A arms for the 6. I watched several videos on the subject. There was one that even showed a guy wrapping plumbers Teflon tape around the arm and bushings as means of providing a squeak resistant surface. My confusion is the use of grease/Teflon and grease on the outer surface of the bushings. I would think you would want resistance on the outer surface and movement on the inner surface. What is the theory (IMG:style_emoticons/default/confused24.gif)
Replies(1 - 7)
jhynesrockmtn
post Nov 30 2025, 11:37 AM
Was that install a non rubber bushing? If stock rubber, just follow Ian Karr's videos. I redid all of the suspension on my BB following his videos and it turned out great.
rick 918-S
post Nov 30 2025, 12:21 PM
I watched Ian's vid
I was going.to ask him if he greased the out to allow a smoother install. Anyway just an over thought question I think. (IMG:style_emoticons/default/idea.gif)
bdstone914
post Nov 30 2025, 12:29 PM
bdstone914
QUOTE(rick 918-S @ Nov 30 2025, 12:21 PM) *
I watched Ian's vid
I have installed several sets and can call you wirh some tips.
Bruce
TheRuttmeister
post Nov 30 2025, 12:32 PM
You don't want to use grease on rubber bushings. You risk the grease damaging the rubber. Depending on which rubber and which grease, the life of the rubber can be greatly reduced.
Poly bushings were developed for racing which doesn't care about squeaky suspension.
With metal bushings you usually want the bushing fitted on one side (ID or OD), but that's mostly for reasons that don't apply here.
In theory lubrication on the OD of the bushings will last longer as the OD is under less stress per unit area. With Poly bushings I'd just put graphite or some other dry lubricant on them, inside and out. Teflon spray would work. Teflon tape is just going to get torn up, its a sealant, not a lubricant.
Superhawk996
post Nov 30 2025, 01:26 PM
QUOTE(TheRuttmeister @ Nov 30 2025, 02:32 PM) *
(IMG:style_emoticons/default/agree.gif) X10
Use KY jelly, Astroglide, or even dish soap. Never use grease. Those water based lubricants dry out and let the rubber grip the mating parts.
Rubber bushings are not meant to rotate. They should grip both the A-arm and the bushing housing tightly. Grease on those surfaces will allow rotation and will tear up and wear out the bushing in very short order.
rick 918-S
post Nov 30 2025, 02:07 PM
QUOTE(Superhawk996 @ Nov 30 2025, 01:26 PM) *
Oh ya, soap. That is what I remember. The Teflon one must have been delron
TheRuttmeister
post Nov 30 2025, 02:10 PM
The Teflon one mu a t have been delron
Delrin is a "self lubricating" polymer, so Teflon would be a waste of time.
5 User(s) are reading this topic (4 Guests and 0 Anonymous Users)
1 Members: ledfoot
- Lo-Fi Version Time is now: 30th November 2025 - 09:08 PM
