> 6 install... what's needed
beltwerks
post Dec 6 2025, 04:15 PM
As a newcomer to the world of the 914 i will be asking some rookie questions. (IMG:style_emoticons/default/biggrin.gif)
I'm about to remove the 1.7 engine from my car as i intend to install a 6 engine once restored. Is there anything i need to keep from this engine before i offer it for sale .?
Wiring, clutch, flywheel etc.
Thanks in advance
Dave
Replies(1 - 10)
post Dec 6 2025, 04:25 PM
914-6 GT in waiting
I cant think of anything from the engine that gets used for the conversion.
930cabman
post Dec 6 2025, 04:33 PM
A reasonably large bank account to start
Dr 914, Auto Atlanta has a booklet describing most of whats required, Pelican also has something
It's a process, but keep the questions coming. We will get you through
beltwerks
post Dec 6 2025, 05:14 PM
Thanks for the replies, much appreciated. I will keep on reading and try to learn. Now, if anyone wants any seatbelt advice i'm your man.
Ninja
post Dec 6 2025, 06:33 PM
Does the 1.7 run?
I might leave it in to debug the chassis.
A Porsche 6 conversion is complicated and expensive.
There are more threads regarding these types of conversion here than anywhere else.
You've come to the right place...
Spend some time going through the threads!
sixaddict
post Dec 6 2025, 07:14 PM
There are many people on here that are far more knowledgeable than I and you have a great start from some of the best. I have done a couple and have a few suggestions.
First is a lot of people have their preferences……motor mounts for example….. You have several choices so do your homework. You also have choices when made early can be easy. There are things people don’t do…..like removal of -4 engine mounts to make it cleaner.
Depending on your use street/track or both you have choices on brakes and cooling that are best made early in your build. It’s a matter of how deep you want to go…….Welcome and good luck with your build.
Just my 2 cents.
mb911
post Dec 7 2025, 05:16 AM
I can help with questions and parts 914-6werkshop.com
IronHillRestorations
post Dec 7 2025, 09:54 AM
I. I. R. C.
I’ve done a few 6 conversions and always glad to help.
I also make engine harnesses for 6’s and 6 conversions, send me a PM and I can help.
mlindner
post Dec 7 2025, 01:35 PM
Yup, Perry Kiehl for a engine harness...just the best. I would also recommend starting with the basics. In Wisconsin, heated A/C garage, some kind of lift, build box to roll motor and trans into position. Your going to do this a few time to get everything right. And Ben McFarland has all the knowledge as to oil, exhaust, mounting. Then you go to PMB for all the brake upgrades you will want. And 914world will have the rest. Best, MarkAttached Image Attached ImageAttached Image
beltwerks
post Dec 7 2025, 04:30 PM
Thanks for all the advice and offers of help. This build will be a slow burner whilst i learn and read as much as i can.
930cabman
post Dec 7 2025, 04:38 PM
QUOTE(mlindner @ Dec 7 2025, 02:35 PM) *
Show off!!
wish my /6 conversion was this sweet
are you toting bags of potatoes for hire these days?
- Lo-Fi Version Time is now: 12th March 2026 - 03:35 AM
