| Spoke |
Dec 7 2025, 09:37 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,348 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
While turning into a parking space I felt a tug on my hand. My finger snagged my key chain and mortally bent the key. Being the only key I have I'm down to starting my car with a pair of pliers.
Who can re-cut 914 keys? I tried once locally an no one would do it. Attached image(s)
| 76-914 |
Dec 7 2025, 09:45 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,865 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Curt, our resident locksmith.
| Luke M |
Dec 7 2025, 10:29 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,468 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
My local Porsche dealer was able to cut one for me.
They did want a registration card/title with my info on it before doing so. |
| chmillman |
Dec 7 2025, 11:07 AM
Member ![]() ![]() Group: Members Posts: 357 Joined: 15-June 24 From: Switzerland Member No.: 28,183 Region Association: Europe
While turning into a parking space I felt a tug on my hand. My finger snagged my key chain and mortally bent the key. Being the only key I have I'm down to starting my car with a pair of pliers. Who can re-cut 914 keys? I tried once locally an no one would do it. Well, you're probably going to have to remove the ignition switch to get the rest of the key out anyway... Once you have the broken piece to copy from, a decent key-maker person might be able to clamp it in their key-copy machine. Key blanks seem to be easily available. |
| bdstone914 |
Dec 7 2025, 11:43 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,264 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
You may be able to dig out the broken part with two sharp picks. Any locksmith should be able to cut a key. Call around locally. Its a common VW blank.Curt can do it too. Do you have a spare to copy? If not pull the rear trunk lock and have a key made to it. Much easier than pulling the ignition lock.
@spoke Make at least two keys. |
| mepstein |
Dec 7 2025, 11:58 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,508 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I’ve always been able to get them out with very small needle nose pliers or a pick. Call around to your local locksmith and if nobody wants the job, send it to Curt/TheCabinetmaker. He did a broken key for me and it was an excellent job.
| windforfun |
Dec 7 2025, 12:12 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,091 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
I had these made at the local locksmith. IIRC, I bought the blanks on eBay.
Attached thumbnail(s) |
| Spoke |
Dec 7 2025, 02:43 PM
I had these made at the local locksmith. IIRC, I bought the blanks on eBay. Thanks. Bought 3 blanks from ebay. I took one to a local dude and he said he couldn't do it and when I pressed him about it he cut the key and really f-ed it up. I think he was pissed that he didn't sell me a key. |
| windforfun |
Dec 7 2025, 04:13 PM
Half of the locksmiths I've used over the years spent time in prison. They love to talk about it too.
(IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/dry.gif) |
| wonkipop |
Dec 7 2025, 05:14 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,437 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
You may be able to dig out the broken part with two sharp picks. Any locksmith should be able to cut a key. Call around locally. Its a common VW blank.Curt can do it too. Do you have a spare to copy? If not pull the rear trunk lock and have a key made to it. Much easier than pulling the ignition lock. @spoke Make at least two keys. yeah i managed to get a broken key out of our forklift with a pick. its doable with a bit of patience. |
| PlantMan |
Dec 7 2025, 05:40 PM
Member ![]() ![]() Group: Members Posts: 457 Joined: 14-May 14 From: Mission Viejo Member No.: 17,352 Region Association: Southern California |
I’ve always been able to get them out with very small needle nose pliers or a pick. Call around to your local locksmith and if nobody wants the job, send it to Curt/TheCabinetmaker. He did a broken key for me and it was an excellent job. Me too, slow and steady and it slipped out for me.... Try to find a local guy who does work on old VW's. I was lucky to find a guy by my office and he was thrilled to do it for me and make extra keys. He was really into the project... I love people like that who appreciate craftsmanship. I took the tumbler and the broken key to him and he fixed me up the next day. |
| windforfun |
Dec 7 2025, 06:37 PM
Try shoving some thin double sided sticky Scotch tape in there. Perhaps this has already been suggested.
| JamesM |
Dec 7 2025, 07:47 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,182 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
While turning into a parking space I felt a tug on my hand. My finger snagged my key chain and mortally bent the key. Being the only key I have I'm down to starting my car with a pair of pliers. Who can re-cut 914 keys? I tried once locally an no one would do it. Do you only have the one key? There is nothing special about 914 keys, any competent lock shop should be able to cut them. Lock shop near me actually carries the proper black plastic head Porsche keys as well as the valet profile keys. Not sure if that is just because I am lucky or because I have had then cut so many of my own I brought in that they decided to stock them. That said if you don't have a competent locksmith near you @TheCabinetmaker Curt should be able to sort you out. Anything beyond cutting a key or re-wafering a single tumbler or two we sent to Curt. Get multiples made, then you wont have to do this again. |
| JamesM |
Dec 7 2025, 07:49 PM
Half of the locksmiths I've used over the years spent time in prison. They love to talk about it too. (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/dry.gif) Probably related to having an interest in getting past locks when you don't have a key. |
| TMM914 |
Dec 7 2025, 09:42 PM
Member ![]() ![]() Group: Members Posts: 66 Joined: 1-January 20 From: St Jacobs Ontario Canada Member No.: 23,786 Region Association: Canada
Once the extraction has been successful……tell the locksmith it’s for a Volkswagen not some semi rare vintage Porsche…….i bet he will give it a try!
| Artfrombama |
Dec 7 2025, 10:23 PM
Artfrombama ![]() ![]() Group: Members Posts: 431 Joined: 21-January 24 From: One of the chosen few Member No.: 27,870 Region Association: South East States
Took the only (broken valet) key for my car to a locksmith, he had no blanks so I bought two sets off eBay. Took them back to the locksmith to get cut. The locksmith ruined one key and told me to GTFO!
Took them to the kid at the mom and pop hardware store, cut them no problem. When I told him they were for a Porsche, N/C! |
| JeffBowlsby |
Dec 9 2025, 01:12 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,198 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
As I recall, you can disassemble the lock, and remove the lock cylinder. Remove the screw at the end of the cylinder that attaches the cam, and remove the cam. Insert a probe into the screw hole at the end of the cylinder and push the key remnant out.
| Spoke |
Jan 13 2026, 01:48 PM
Finally got around to looking at the broken key. Got it out very easily with a pair of tweezers. Had to remove the steering wheel to get a good view.
![]() About the Steering wheel, it turns out the key chain got stuck between the wheel spoke and the horn button. As I was backing out of a parking space and spinning the wheel to the left, my hand hit the key chain and miraculously the key chain (leather) got stuck and as I continued to turn the wheel, I felt a resistance as the key was being bent. (IMG:style_emoticons/default/headbang.gif) ![]() |
| mate914 |
Jan 13 2026, 02:57 PM
Matt ![]() ![]() ![]() Group: Members Posts: 934 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States
Curt made my keys from a picture. I see you have a picture, might want to edit that part out.
Matt |
| frank_c |
Jan 14 2026, 12:09 AM
Member ![]() ![]() Group: Members Posts: 78 Joined: 29-December 24 From: Austin, TX Member No.: 28,542 Region Association: None |
Curt made my keys from a picture. I see you have a picture, might want to edit that part out. Matt Curt made a key for my 914 from only a picture of the key as well. I used a similar service to make replacement keys for the two 911s. So yes, you may want to consider removing that picture from your post (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 3rd March 2026 - 04:52 AM |
