| 914043 |
Dec 10 2025, 12:38 AM
Member ![]() ![]() Group: Members Posts: 102 Joined: 2-April 19 From: California Member No.: 23,007 Region Association: Central California
| Dave_Darling |
Dec 10 2025, 02:36 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,326 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Nice! It might be a bit too low, but the angle of the driveway makes it a bit difficult to tell.
--DD |
| VaccaRabite |
Dec 10 2025, 06:21 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,840 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Looks like a submarine emerging.
You will need bumpstops from the front and crank it down till level. And then you will need an alignment. Zach |
| Cairo94507 |
Dec 10 2025, 07:53 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,586 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
They look good low, but the rear is very low and I think needs to come up at least 1", maybe more. I have mine set so it sits higher in the rear than the front by about 1/2". (IMG:style_emoticons/default/beerchug.gif)
| worn |
Dec 10 2025, 07:16 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,555 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
| bkrantz |
Dec 10 2025, 08:46 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,616 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Here's my quick edit to get the wheels close to horizontal. The car now looks very level. That's fine, but I prefer just a bit of forward rake.
Attached thumbnail(s) |
| mepstein |
Dec 10 2025, 08:49 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,508 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
They look good low, but the rear is very low and I think needs to come up at least 1", maybe more. I have mine set so it sits higher in the rear than the front by about 1/2". (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/agree.gif) |
| Front yard mechanic |
Dec 10 2025, 09:53 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,426 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None
Lower
| Retroracer |
Dec 11 2025, 11:25 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 653 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest
They look good low, but the rear is very low and I think needs to come up at least 1", maybe more. I have mine set so it sits higher in the rear than the front by about 1/2". (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/agree.gif) . (IMG:style_emoticons/default/agree.gif) - Tony |
| windforfun |
Dec 11 2025, 11:32 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,091 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
New springs needed?
| sixnotfour |
Dec 11 2025, 11:34 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,147 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
15x7s, 205/55, 120lbs adjustable perches..
| flxzcat |
Dec 11 2025, 01:24 PM
Member ![]() ![]() Group: Members Posts: 98 Joined: 13-June 11 From: Lake Forest, So. Cal. Member No.: 13,188 Region Association: Southern California |
lower the front 1" and raise the back 1"
| Shivers |
Dec 11 2025, 01:50 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,295 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Looks like a submarine emerging. You will need bumpstops from the front and crank it down till level. And then you will need an alignment. Zach (IMG:style_emoticons/default/agree.gif) Sorry man but an inch down in front is probably close. The back is righteous |
| rgalla9146 |
Dec 11 2025, 06:49 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,942 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Take a picture on level ground. Pretty widely agreed that nose down and low is best. Nose up is worst. Just sayin' |
| PanelBilly |
Dec 11 2025, 09:23 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
| Patrick_139 |
Dec 12 2025, 10:58 AM
Newbie ![]() Group: Members Posts: 19 Joined: 2-March 24 From: Claremont Member No.: 27,975 Region Association: Southern California |
| brant |
Dec 12 2025, 02:01 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,150 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
you really need front rake (lower in the front than the back) for best handling and weight transfer.
additionally... your front looks pretty low to me, but I'm not there in person to tell. if you get your front too low... I guarantee you will blow both shocks out within a year. too low and the shocks do not have rull range of travel. you can buy custom length of shocks to accomodate this.... or raise it back up to have shock range. my race car has custom shorter shocks and custom shorter struts to allow this. too low also creates very bad handling as you are on the bump stops each bump... and the shocks are unable to do their job |
| StarBear |
Dec 12 2025, 03:41 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,239 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States
Looks like a submarine emerging. You will need bumpstops from the front and crank it down till level. And then you will need an alignment. Zach (IMG:style_emoticons/default/agree.gif) Sorry man but an inch down in front is probably close. The back is righteous (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 2nd March 2026 - 11:43 PM |
