> 914World Classifieds Rules
> F/S 914 Gauges
sysintspec
post Jan 5 2026, 04:45 PM
I'm new here ...
More stuff from the attic.
Have tach, speedo, fuel gauge from 1973 1.8
Speedometer needs a new trim ring as existing one is dented.
$ 240.00 Buyers pays shipping
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
Replies(1 - 4)
scallyk9
post Jan 5 2026, 07:02 PM
Actually, correct for 70 through 73 1.7 or 2.0
Montreal914
post Jan 5 2026, 07:09 PM
73 model had 1.7 or 2.0 selection. Your speedometer being 150mph means these were from a 2.0 most probably.
The biggest question here is: does the odometer work?
One way to test it is to use a square bit in your drill IN REVERSE and insert it where the speedometer cable connects to. Your speedometer needle will get to speed and you should add a mile after a while. Your trip odometer will move too!
Good luck with the sale! (IMG:style_emoticons/default/smile.gif)
sysintspec
post Jan 6 2026, 08:19 AM
I'm new here ...
QUOTE(Montreal914 @ Jan 5 2026, 08:09 PM) *
You're right .Came from 2.0 Just tested and both speedometer and odometer work.
post Jan 6 2026, 11:14 AM
I'm new here ...
[quote name='sysintspec' date='Jan 6 2026, 09:19 AM' post='3239699']
[quote name='Montreal914' post='3239641' date='Jan 5 2026, 08:09 PM']
[/quote]
[/quot
Would you consider individual sale and if so what would you want for the speedometer?
- Lo-Fi Version Time is now: 8th January 2026 - 05:57 PM
