> Windshield Washer Electric Pump, Makes noise, but no squirt
DennisV
post Jan 10 2026, 08:35 PM
Testing the windshield washer in our 1970 914-6. When I pull the wiper / washer lever I can hear a slight thud or click and then the wipers cycle. I have confirmed the noise is the electric pump as I can feel it move slightly if I put my hand on it while someone else pulls the lever. Does that mean the pump is good, or does a good working pump make a different noise?
I've been through many threads about the squirters not working, but haven't found much discussion about the electric pump itself.
Thanks.
Replies(1 - 19)
Superhawk996
post Jan 10 2026, 08:53 PM
Should be a constant hum / whirring
Clunk / thunk / click isn’t right.
Bench test it.
porschetub
post Jan 10 2026, 08:54 PM
QUOTE(DennisV @ Jan 11 2026, 02:35 PM) *
Thanks.
it's cheap enough as it is a 911 part shop around for the best price ,cheers.
johnhora
post Jan 10 2026, 09:06 PM
DennisV....The pumps get gummed up inside and make noise and don't do any pumping...I've actually taken them apart and removed the crud and gotten them to work. also go slow as I think I remember a little thin gasket around the perimeter of the two sides
rgalla9146
post Jan 11 2026, 07:04 AM
Original pumps are dated approximate to (but before) the cars manufacture date.
I've had good luck disassembling, cleaning and reassembling them.
Get the pump bracket and hardware plated while it's apart.
914Sixer
post Jan 11 2026, 07:30 AM
Clean the whole system if you have to take pump apart.
DennisV
post Jan 19 2026, 02:19 PM
QUOTE(johnhora @ Jan 10 2026, 07:06 PM) *
Thanks for the suggestion John. I cleaned the internals and it's purring along now.
I couldn't find an existing DIY video on this, so I made one. Very utilitarian and not near the production quality of Ian, but maybe it will help someone else.
Porsche Electric Windshield Washer Pump Restoration
Cairo94507
post Jan 20 2026, 08:01 AM
Michael
Hey Dennis, great job on the washer motor video. I now need to add that to my list as mine has never worked. Thanks for taking the time to make the video. (IMG:style_emoticons/default/beerchug.gif)
johnhora
post Jan 20 2026, 03:51 PM
(IMG:style_emoticons/default/agree.gif) Nice informative video Dennis..
NARP74
post Jan 20 2026, 05:04 PM
Nice video. The grease you used will wind up in the hoses and on the windscreen, but the washer fluid should dilute it soon enough. Might get a smear initially.
Great save.
Steve
post Jan 20 2026, 08:49 PM
Enlarged prostate? Jk.. I had to prime mine to get it to work.
DennisV
post Apr 6 2026, 02:00 PM
A related tip on this topic. The hoses are secured to the pump with very thin wire (0.80 mm diameter) twisted around them. It broke when I removed it.
The closest I could find is 24 gauge floral wire at Menards. It is 0.60 mm diameter and green, but worked quite well and is out of view.
BillC
post Apr 6 2026, 04:06 PM
QUOTE(DennisV @ Apr 6 2026, 04:00 PM) *
That looks like safety wire. Readily available at any speed shop, as well as Summit Racing, Jegs, Amazon, etc. The twisting is done with a special pair of pliers that has a pull-twister, specifically for safety wire.
914Sixer
post Apr 6 2026, 06:49 PM
Wire is NOT stock.
rgalla9146
post Apr 6 2026, 07:38 PM
QUOTE(914Sixer @ Apr 6 2026, 08:49 PM) *
Wire is NOT stock.
fresh hose will not need it.
DennisV
post Apr 7 2026, 06:48 AM
QUOTE(914Sixer @ Apr 6 2026, 05:49 PM) *
Wire is NOT stock.
(IMG:style_emoticons/default/ohmy.gif)
Thank you for pointing this out.
aturboman
post Apr 9 2026, 11:09 AM
As mentioned the original pumps have date markings on the bottom plate. This is an original pump which a also disassembled and cleaned by removing the 4 cover screws.
This is a very simple gear pump so if the motor runs your pump should work fine.
Here is an image of all the original check valves and fittings with new hose.
Again the new hose will be very tight on the pump nipples and no clamps required.
I find that heating the hose end slightly with a head gun and a little shot of silicon spray will allow them to easily slip on, once cooled it will be tight and not leak.
Lastly make sure you have the connections correct at the washer reservoir, they are easily reversed.
Only one nipple has the pick-up tube running to the bottom, this has to go to the suction side of the pump, the other is the return for the pressure circuit. If the are reversed you're pumping air not water.
DennisV
post May 26 2026, 05:04 AM
QUOTE(aturboman @ Apr 9 2026, 10:09 AM) *
Well after all that it still doesn't squirt. I hear it spinning away, but no result. I ran it several long bursts thinking it might need to prime it self, but nothing. I pulled the hoses and put my finger on the I don't feel any suction or pressure. I assume it should be strong enough to feel something.
Maybe this was a wasted effort, as the date code on ours appears to be 3 77. So vintage, but not original to the car anyway.
Superhawk996
post May 26 2026, 11:05 AM
Bench test rather than playing with it in car. Air must be leaking in somewhere.
Or . . . $30 for a new one.
I’d you want to keep going with this one, make sure the rubber gasket isn’t torn and allowing air in.
If it were me I’d put a dollop of a water soluble gel on the gears (KY or similar) to help it prime. Pump needs to be lower than reservoir. Don’t count on suction to lift washer fluid to it but bench testing will confirm how high it will lift.
Cairo94507
post Jul 7 2026, 04:08 PM
Michael
I just spent the afternoon trying to sort my washer pump not working. It made noise like the pump was working but no water coming out the nozzles. Pulled the bottle out and removed the washer pump. Disassembled and it looks perfect. Bench tested and it pumps out water.
Then pressurized the water lines to make sure they were not somehow kinked. They seemed fine.
Looked at the bottle and saw the water pickup lying in the bottom. Pulled it out and it was dirty. Cleaned it, cut a new piece of tubing and then had to get the hose attachment piece off the bottle so I could put the new hose with pickup on it. That popped off the bottle with little drama and the new case went on with no problem and then reattached it to the bottle.
Now I have to sort the lines.... I forgot where they were connected. There are 2 connections to the bottle and 2 connections to the pump. Couldn't be that tough, right? I tested the system by inserting one line into a water bottle and the washers squirt quite nicely. So, in theory, once I hook everything up correctly, that will be job done.
Will tackle that tomorrow, time permitting. (IMG:style_emoticons/default/beerchug.gif)
- Lo-Fi Version Time is now: 22nd October 2026 - 12:51 PM
