| fiberglass1inc |
Jan 14 2026, 03:42 PM
Newbie ![]() Group: Members Posts: 17 Joined: 13-April 14 From: WPB Florida Member No.: 17,248 Region Association: None |
Hello 914 brothers and sisters! I have a 73 914 with a 75 engine. Had some issues with the light switch which I believe is a 75 switch (12 pin, the 73 switch is 9 pin). When the turn signals are used they don't work and the low oil pressure light comes on (pressure is not low). This is recent, always worked before. Has anybody seen anything like this? Thank you in advance.
| JeffBowlsby |
Jan 14 2026, 04:17 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,212 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Headlight switch? The 73 switch should be a 10-pin, the 75 switch is an 11-pin.
They are functionally identical, doubt the headlight switch is the cause of the issue you are experiencing. |
| emerygt350 |
Jan 14 2026, 04:47 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,476 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Grounding issue?
| fiberglass1inc |
Jan 15 2026, 09:38 AM
Headlight switch? The 73 switch should be a 10-pin, the 75 switch is an 11-pin. They are functionally identical, doubt the headlight switch is the cause of the issue you are experiencing. Thank you for that, thought it was 9 and 12 but been a while since i looked at it. Does actually sound like a ground issue. |
| JeffBowlsby |
Jan 15 2026, 09:55 AM
The grinding may be a defective switch (inspect it further...the rheostat within it may be bad), but the switch is not related to low oil pressure. Also, look at your turn signal switch, it may be going bad.
| Dave_Darling |
Jan 16 2026, 12:47 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,328 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Does the tach drop to zero at the same time you hit the brakes? If so, check fuse #8 or #9; it can cause that kind of behavior if it's popped.
Come to think of it, check those fuses anyway. --DD |
Lo-Fi Version | Time is now: 17th March 2026 - 05:54 PM |
