| saigon71 |
Jan 17 2026, 06:05 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,019 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region
All hold down clips intact. Shipping weight is 27oz, 12 X 10 X 8.
| rfinegan |
Jan 18 2026, 07:13 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,189 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region
ill take this...
| saigon71 |
Jan 18 2026, 07:53 AM
"SOLD"
| TRP |
Jan 18 2026, 09:49 AM
Member ![]() ![]() Group: Members Posts: 237 Joined: 2-September 23 From: Morgan Hill, CA Member No.: 27,559 Region Association: None
ill take this... @rfinegan - I think I know what you're going to do with this part. Please share your progress. |
| rfinegan |
Jan 18 2026, 10:21 AM
If this goes as expected the removal of the air flow box and replace with this adapter tube to the Throttle body rubber hoses/tubes....
| TRP |
Jan 18 2026, 07:24 PM
I knew it! I am interested in your progress as I am toying with a similar idea to increase airflow into my 2056 w/ the gowesty throttle body.
I would like to know more about that flange you have there. |
| rfinegan |
Jan 19 2026, 02:13 AM
This pipe replaces the barn door flow box of the Ljet for a modern vacuum GM MAP sensor (typicaly used in replacement EFI systems) So the stock air filter box can be used. Once Im up and running with at the stock Throttle bodying base "Running" tune, Ill update to to large GoWesty and tune again as needed. What EFI are you going to use? Or for flow, open the bottom air inlet(snorkel) it will be the size of the old throttle plate too. Cold air source is best and piped as needed. There are lots of threads on this cheap fix here on the 914 WORLD SEARCH Best to start a build ahead so we can follow along I knew it! I am interested in your progress as I am toying with a similar idea to increase airflow into my 2056 w/ the gowesty throttle body. I would like to know more about that flange you have there. |
| rfinegan |
Jan 23 2026, 09:32 AM
Lo-Fi Version | Time is now: 13th March 2026 - 05:08 AM |
