> total engine oil capacity
Geezer914
post Jan 20 2026, 07:11 AM
Geezer914
I am trying to figure out how much additional oil is needed when adding an external oil cooler and a Billet aluminum Tuna can? 10 ozs. sound right? 3.7 qts. + tuna can equals 4 qts. of oil.
Setrab oil cooler .53 qts. or 17.2 oz.
110" of 1/2" hose 12 oz.
engine oil + Tuna can 4qts.? 128 oz.
total 157 oz. or 4 qts. + 29 ozs.
So I would need 4 qts. plus an additional 29 ozs. of oil???
Replies(1 - 7)
Cairo94507
post Jan 20 2026, 09:09 AM
Michael
That sure seems like you are in the ballpark to fire it up, drive it, check it after the thermostat opens and know oil is flowing as planned. (IMG:style_emoticons/default/beerchug.gif)
Chad911sc
post Jan 23 2026, 08:07 AM
I have the exact same set up as you….
I wondered the same thing.
I was running my engine during the break in period and the tuning, before I had to take it all back apart, with 4.3 quarts. Never could figure out how much of my oil was draining back from the cooling system into the case after shutdown. I always had about 3mm over the full line after cool down.
brant
post Jan 23 2026, 09:08 AM
Is it a front cooler or rear?
My 4 has a front earls cooler with tuna can and is 6-7 quarts
Chad911sc
post Jan 23 2026, 12:57 PM
It’s a rear mount under the trunk floor.
Geezer914
post Jan 23 2026, 04:51 PM
Geezer914
Rear mount cooler under the trunk floor. Added the volume of the cooler and hoses and came up with 29 ozs. The tuna can brings the normal capacity to 4 quarts. So 4 quarts plus 29 ozs.
Chad911sc
post Jan 25 2026, 05:29 PM
How does it look on your dip stick after the engine cools? Is it higher than full mark? Or do you have a one way stop valve in the cooling system? I guess I am getting some drain back due to it being a few mm above full when cool.
@geezer914
Geezer914
post Jan 26 2026, 06:41 AM
Geezer914
I have not started the car as yet, 17° here with a foot of snow!
- Lo-Fi Version Time is now: 12th March 2026 - 06:07 AM
