Tobra |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 ![]() |
What diameters and quantity will I need to replace all my vacuum hoses. There appear to be various sizes on first glance. Is this something that will be delineated in the Haynes I am picking up on Tuesday at the stealership. Vacuum lines, a new Bosch Blue coil and petronix are going to be the first things I do, after changing engine and transaxle oil, and flushing the brake fluid of course.
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
dave darling's vaccum line tech article at the bird gives all the sizes and lengths. good diagram too. i printed it out yesterday. if you're going to flush the brake fluid, get speed bleeders for all four corners.
k |
Tobra |
thank you sir, speed bleeders already on the list
Tobra |
After checking out the DD vacuum hose diagram, it appears that there are about 15 feet of the 12 mm ID hose, can this be correct, are there really three different 36" sections?
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,244 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Yes and no... The lengths were what was on my car, plus a "fudge factor". I suggest measuring the lengths of the hoses on your car--or run some string along the approximate hose routing, and measuring that. Add some fudge factor for mistakes, and there you go.
The diameters listed are the diameters of the fittings the hoses go on. Actual hose IDs are generally going to be a little bit smaller. --DD |
Tobra |
At the PP site it lists the hoses by sizes in diagram, I suppose to avoid confusion. I want to replace everything rubber under the hood, just in case, won't do injector seals unless it is whistling at me, but those are getting done too eventually.
meares |
Member ![]() ![]() Group: Members Posts: 403 Joined: 23-March 05 From: Atlanta Member No.: 3,800 ![]() |
i got mine from (gasp) AA....installed them last night.....they did a great job!! they are the woven original kind....they look cool! it was only $75....they cut it right then and there and they have a really nice vacuum diagram too! highly recommended! (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
Lo-Fi Version | Time is now: 31st August 2025 - 09:13 PM |
