| Uraquan |
Jan 27 2026, 10:19 AM
Newbie ![]() Group: Members Posts: 3 Joined: 22-March 19 From: Atlanta, GA Member No.: 22,981 Region Association: South East States
This is for anybody else doing a clutch cable install or adjustment. If you bought a new pin for the clevis at the pedal cluster, make sure that the pin goes through both sides.
I fought with this thing for hours thinking that I was just angling it wrong or something. I finally had enough and said to myself it can't be this hard. Tested the pin and the clevis outside the tunnel and sure enough it would only fit through one side. The old one fit through both sides no problem. So used a file to open the stubborn hole just a little bit and had that cable installed in seconds. TL:DR test the pin and clevis outside the car before attempting install. |
| slapshot |
Jan 27 2026, 02:54 PM
Member ![]() ![]() Group: Members Posts: 146 Joined: 11-June 23 From: Utah Member No.: 27,409 Region Association: Rocky Mountains
That's good to know. Thanks
I just replaced mine after I had to trailer the car home. In my case, the clutch tube broke free and tore the firewall. For those still needing to replace theirs, I’d recommend reinforcing the firewall around the tube while the cable is out—especially if there’s any sign of softness—and checking the clutch tube welds both at the firewall and near the shifter. |
| 914Sixer |
Jan 27 2026, 02:59 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Wecome the the world of AFTERMARKET CRAP. They seem to be able to NOT check anything for proper fitment.
| worn |
Jan 27 2026, 09:28 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,533 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest
Lo-Fi Version | Time is now: 27th January 2026 - 11:29 PM |
