> Heater blower Fan -Ground wire
young55961
post Jan 29 2026, 11:01 AM
Hi,
I just replace a new motor to the Heater blower box. I know the connector wire consist of four wires, the main power, and 3 control, but where the ground wire.
Did I miss anything?
Billy
Replies(1 - 6)
JeffBowlsby
post Jan 29 2026, 12:03 PM
The heater fan is in the engine bay and has only two wires. I think you are referring to the fresh air fan under the cowl? If so the ground is through the fresh air fan relay.
Check the schematics for your model year here:
https://bowlsby.net/914/WiringHarnesses/#ReferenceLibrary
TRP
post Jan 29 2026, 01:35 PM
To Jeff's point, heater blower fan is in the engine bay with two wires, orange and green on a 75. Those two wires have connectors that go to the harness by the relay board.
young55961
post Jan 29 2026, 01:39 PM
QUOTE(JeffBowlsby @ Jan 29 2026, 01:03 PM) *
Yes, I am referring to the fresh air fan.
Mine is a 1975 914. I’m still a bit confused. I’m looking at the entire assembly, and it appears to be all plastic. How is it grounded?
Regards,
Billy
cholland_
post Jan 29 2026, 01:47 PM
If I recall, theres a red and white wire that provides power from the fuse box.
The other three white wires provide ground via the control panel in the dashboard, through the speed resistor pack.
young55961
post Jan 29 2026, 02:13 PM
QUOTE(cholland_ @ Jan 29 2026, 02:47 PM) *
Thank you.
I understand now.
930cabman
post Jan 29 2026, 05:04 PM
Hope you got it worked out
- Lo-Fi Version Time is now: 29th January 2026 - 06:48 PM
