> Euro front turn signal bucket position lamp socket contact, Original or hackety-hack hack...?
chmillman
post Feb 2 2026, 02:42 PM
Region Association: Europe
One for the Euro guys - I know you are relatively few and far between - original spec US cars have full yellow front TS lenses, Euro cars have a small white (clear) portion at the bottom which is a "position lamp" - or parking light. Goes on with the taillights in the first position. Equipped with a 5W BA15s based bulb (R5W).
So, I was thinking of adapting these to become DRL's. I found a few LED's with a BA15s base which claim to have up to 500-600 lumens or more. Same 5 watt draw, but LEDs. So I pulled the lenses off in order to measure how much clearance there is between the bulb and the lens - it's about 10-12mm - the LED's are a bit longer than the standard bulbs, but should still fit. Then I pulled one of the bulbs out to just see what the socket looks like... tried to at least, the bulb would not budge. So I finally pulled out the whole little assembly (held on by 2 screws) and realised that the bulb base was just stuck in there by some oxidation. In getting the bulb loose, the bottom (center) contact came out. And it looks very odd.
To me this looks like something someone hacked together from two uninsulated spade connectors which then just got jammed into the slot. The funny thing is that both left and right sides have the same thing...
I went looking to see if there was a replacement part for the socket and the parts diagram doesn't show anything separate other than the bulb - which makes me feel that if a socket went bad, one had to basically replace the entire TS bucket. So maybe someone hacked the solution above together in order to avoid this - the buckets themselves are actually in pretty good condition.
I'm not at all fond of the current solution - if the contact attached to the wire falls out and contacts the bucket body, I'll have a short. So even if the DRL project doesn't work out, I am now wanting to replace the sockets. I may need to try to adapt something like the following:
However, there's not all that much depth there behind the base, maybe 30mm max. Have to get a couple and see if they might fit.
So basically the question I wanted to ask is - has anyone gone through the same thing with their Euro-spec TS buckets? TIA.
Replies(1 - 8)
JeffBowlsby
post Feb 2 2026, 03:43 PM
Mitch you are probably aware those are not factory original euro buckets, the aluminum plate is definitely aftermarket. Everything is kludgy about those. You might consider finding some real buckets in ebay.de or some other source, might be the easiest way to resolve.
post Feb 2 2026, 03:56 PM
914-6 GT in waiting
Buy some Spokeworks led lights. No mods needed. Just plug and play.
wonkipop
post Feb 2 2026, 04:01 PM
you are correct about having to buy the entire bucket.
i have both the USA parts catalogue and the ROW catalogue.
as is often the case in the PET catalogues they use the same diagrams and often this means the USA catalogue has a misleading diagram esp on more common parts.
but there are three parts listings.
general ROW bucket (except italy) = PCG 631 401 10
italy = 914 631 401 12
USA = 914 631 401 11
small divider for ROW is not listed as a separate part.
to me the one you have looks stock in every way.
except maybe that spade connection. but i have not seen a euro bucket for a long time.
it was 30 years ago and i cannot remember. it was on a J spec car. but it looks right when you view the image of the unit in the factory workshop manual. but they do not have a detail where that divider holder is disconnected from the bucket.
i do have USA spec entire indicator sidelight units i got 20 years ago and no divider/bulb holder in there. but it seems its a universal bucket they fitted the additional divider into for ROW. but i'd have to see one in the flesh to know for sure.
picture from f w m.
wonkipop
post Feb 2 2026, 04:33 PM
i'm only guessing with this, but....
usa bucket.
to me it looks like the bucket itself is a universal casting.
and the pins cast in are for fitting a euro parking light bulb holder divider.
which looks in factory manual to be very similar to what you have in your bucket.
but it would have been bonded in, or glued to those pins.
i think you are right. somebody fixed the bulb holder.
got the divider apart and then to refit it, looks like they drilled holes?
pins probably broke off getting divider out?
post Feb 2 2026, 05:02 PM
Resident German
QUOTE(wonkipop @ Feb 2 2026, 02:33 PM) *
As Jeff mentioned, this is a pretty popular aftermarket mod here in the US.
No stock parts were used in the conversion.
wonkipop
post Feb 2 2026, 05:29 PM
QUOTE(SirAndy @ Feb 2 2026, 05:02 PM) *
yeah i found a pic.
quite a bit more going on in the real deal. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif)
nice little curved reflector - makes sense given its parking lights.
though it says this is aftermarket. but old stock. presumably a reasonable copy of originals?
pretty expensive too if you find one.
burton73
post Feb 2 2026, 06:37 PM
Senior member, and old dude
Here are pictures of my factory euro lights from my 6 back in early 70s
hope it helps
Best Bob B
chmillman
post Feb 3 2026, 02:34 AM
QUOTE(JeffBowlsby @ Feb 2 2026, 10:43 PM) *
No, I was not… Always assumed they were original. Merde.
QUOTE(mepstein @ Feb 2 2026, 10:56 PM) *
Not street-legal here… Would fail the inspection. Hence my idea of just replacing the original bulbs with LEDs – 5 minutes to change them back out for the inspection.
"New" ones here are about $200 a pop and appear to be made of plastic.
Before doing that I will if I can't hack together a reasonable solution that doesn't require replacing the whole bucket.
One of the things that might be concerning if I decide to replace the aftermarket metal buckets with new plastic ones AND do the always-on DRL thing is heat... The original incandescents are 5W. New LEDs going in the same socket will also be 5W or thereabouts. I would think the LEDS would actually produce less heat given that they generate more light (luminous energy) per watt input than incandescents. However, the heat is probably distributed differently. Wondering if the LED lamp base (socket) would get hotter than the incandescent...
- Lo-Fi Version Time is now: 3rd February 2026 - 07:25 AM
