| LefthandRev |
Feb 5 2026, 01:30 PM
Member ![]() ![]() Group: Members Posts: 84 Joined: 9-August 21 From: Seattle, WA Member No.: 25,787 Region Association: Pacific Northwest |
Hi, all.
I pulled my hand brake to park on a hill. When I pulled it up, the button, shaft, and spring shot out like a rocket. No more hand brake! Started looking closer at it and there doesn't seem to be an easy way to fix or replace it - the brake is riveted to the tub and the fatigued shaft just gave up the ghost. What options do I have here? It's a '74, if that matters. |
| Spoke |
Feb 5 2026, 02:06 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,334 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Everything wrt the e-brake comes off with nuts and bolts. Figure out what part broke and replace it.
A single cable from the handle goes to an equalizer to 2 cables; one to each side. Might be time to inspect and replace any other components which look worn/broken. |
Lo-Fi Version | Time is now: 5th February 2026 - 05:55 PM |
