| Marcel Aircooled |
Feb 13 2026, 08:31 AM
Member ![]() ![]() Group: Members Posts: 53 Joined: 28-April 24 From: The Netherlands Member No.: 28,087 Region Association: Europe |
So I bought a standard 38cm steering wheel plus horn and had to replace the spacer and screw set to fix the horn connector.
I got the set from Sportwagen Eckert in Germany (I live in The Netherlands) and not sure what the correct order is to fix the metal and plastic spacers to make my horn work in the end. So I have this: Starting from the horn up side down what do I need to add first before installing the base plate? And what inbetween the base plate and the connector? Finally what on top? Is it just the order from the picture above: horn - black pieces - base plate - orange spacer and big metal spacer - connector - small spacer and screw? Pictures would be perfect! Thanks! |
| Shivers |
Feb 13 2026, 09:19 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,263 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
So I bought a standard 38cm steering wheel plus horn and had to replace the spacer and screw set to fix the horn connector. I got the set from Sportwagen Eckert in Germany (I live in The Netherlands) and not sure what the correct order is to fix the metal and plastic spacers to make my horn work in the end. So I have this: Starting from the horn up side down what do I need to add first before installing the base plate? And what inbetween the base plate and the connector? Finally what on top? Is it just the order from the picture above: horn - black pieces - base plate - orange spacer and big metal spacer - connector - small spacer and screw? Pictures would be perfect! Thanks! I couldn’t find a write up, so I pulled mine apart. Black plastic goes first. Mine did not have the large metal washers (3rd part down in your image.) but there are three bosses casted to the actual wheel that look the same size. |
| Marcel Aircooled |
Feb 13 2026, 09:22 AM
Perfect, thanks so much!
Lo-Fi Version | Time is now: 15th February 2026 - 11:50 AM |
