> Door Glass Removal
nmkimosabe
post Feb 16 2026, 11:24 AM
As a 914 newbie does the entire regulator need to be removed in order to remove the glass or can the forward bolt & plastic block that lifts the window be removed and the window carefully angled to remove it? I need to replace the forward channel guide fuzzy and I don't think it can be done with the window in place.
Replies(1 - 8)
Ishley
post Feb 16 2026, 11:59 AM
https://youtu.be/TMQt5OYOdqQ
The glass can be removed without taking the regulator out. There are two different doors… 70-72 and 73-76. The YouTube video is the later… and is an assembly video but should tell you what you need to know. I Always suggest stating the year of the car on a post as there are differences by year.
nmkimosabe
post Feb 16 2026, 12:02 PM
QUOTE(Ishley @ Feb 16 2026, 10:59 AM) *
nmkimosabe
post Feb 16 2026, 12:03 PM
Thanks Ed for the suggestion and my car is a 1974 1.8. I will search YouTube for the video.
nmkimosabe
post Feb 16 2026, 02:11 PM
I watched the video, but it looks like Ian took the regulator and the guides out first and then reinstalled everything including the glass.
Ishley
post Feb 16 2026, 02:18 PM
Yes but the glass goes in last… so in reverse order you can take the roll up window out and then get to the guide. I assume you’re talking about the rear guide. The front guide is part of the triangle window.
nmkimosabe
post Feb 16 2026, 02:35 PM
Understood and it's the channel insert that is missing in the front guide that is also supports the vent window. I need to insert a fuzzy in the guide and was hoping not to have to remove the window. Thanks.
TonyA
post Feb 16 2026, 03:08 PM
Nachmal
Be careful with that front adjusting screw. If I am not mistaken you could turn it to far and dent the door. Guys am I correct on this ?
nmkimosabe
post Feb 16 2026, 05:29 PM
I could possibly see that happening, but I think I've found the sweet spot on mine and there's plenty of clearance. Appreciate the heads up.
5 User(s) are reading this topic (4 Guests and 0 Anonymous Users)
1 Members: nmkimosabe
- Lo-Fi Version Time is now: 16th February 2026 - 06:19 PM
