| cabrioartie |
Feb 21 2026, 06:48 PM
Newbie ![]() Group: Members Posts: 16 Joined: 8-October 24 From: Las Vegas, NV Member No.: 28,400 Region Association: None
My mechanic recently replaced my CHT and used electrical tape over the spade connectors which I find unacceptable.
I assume there should be a spade housing covering the connectors like so many other places around the engine. I've searched, but haven't found the part. Does anyone know if they are still make it (and the part number) or where I can find a similar housing to use? |
| Literati914 |
Feb 21 2026, 07:09 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,209 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
| Superhawk996 |
Feb 21 2026, 07:17 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,706 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Yup . . . Lazy mechanic beware. (IMG:style_emoticons/default/chair.gif)
If you want OEM connector place WTB in classified - someone can probably come up with one. If you’re not hooked into OEM there are parts like this available commercially. Wiringdepot.com, granger, McMaster Carr, etc are likely sources |
| Superhawk996 |
Feb 21 2026, 07:19 PM
(IMG:style_emoticons/default/agree.gif) This and probably easier to source than my recommendation that may force larger quantity purchase. |
| cabrioartie |
Feb 21 2026, 08:08 PM
Sorry, I don't know if it's just my car, (but it does look original) but the car's wiring harness end is a male connector and this male spade seems very long too, only the CHT end is a female connector.
So, I would need one of these with a female and male on each end. |
| JeffBowlsby |
Feb 21 2026, 10:27 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,191 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Hey Artie, I have just what you need. PM me your address and I’ll get it right out to you.
Lo-Fi Version | Time is now: 21st February 2026 - 10:27 PM |
