> Help machining 930 valve covers
sixaddict
post Feb 26 2026, 08:27 PM
Working on installing 930 valve covers on a 6 conversion.
I need dimensions of the cut that needs to be made to make it work.
Picture would also help either posted or emailed.
Thanks in advance.
Replies(1 - 5)
post Feb 26 2026, 09:22 PM
914-6 GT in waiting
If you sand off 5/16" from the fins, it fits.
gereed75
post Feb 26 2026, 09:30 PM
See if this link works
http://www.914world.com/bbs2/index.php?act...t&id=881470
It can be done with a Dremel.
sixaddict
post Feb 26 2026, 10:11 PM
Perfect….thanks
fixer34
post Feb 26 2026, 10:39 PM
Don't need to take off very much. Took these pictures AFTER I got them fitted, replaced covers with engine in the car.
first 2 are left side, next 2 right side.
Attached Image Attached ImageAttached ImageAttached Image
post Feb 26 2026, 11:25 PM
Remove as little as possible to retain strength, I used a surface grinder with a Harbor Freight flapper disk . fit as you go with the engine in the car, actually goes pretty fast.Attached Image
- Lo-Fi Version Time is now: 27th February 2026 - 03:20 AM
