| mepstein |
Feb 27 2026, 10:55 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,634 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Building another engine for future sale. This one is a 3.2 short stroke. Pauter cranks, canyon head studs, JE 10.5 pistons in Mahle 98mm cylinders. 964 oil pump. Cam for EFI. Twin plug heads with asco valve springs and retainers.
More to come. Attached thumbnail(s) Attached image(s)
| Root_Werks |
Feb 27 2026, 02:55 PM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,947 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
Love to see engines getting built like this. Works of art!
Short stroke 3.2, would it wind up being less than a 3.2? |
| mepstein |
Feb 27 2026, 03:56 PM
Love to see engines getting built like this. Works of art! Short stroke 3.2, would it wind up being less than a 3.2? It’s built on a 3.0 case with 98mm pistons and cylinders. Same cylinder as a 3.2 to 3.4 but the piston needs to be sized for a 3.0 rod. It’s a tried and true combo. |
| mlindner |
Mar 1 2026, 05:54 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,755 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
Very nice Mark. Post more of the build, fun to see it come together.
| mepstein |
Mar 1 2026, 07:39 PM
Cleaning up the cam towers. Removed all the studs to replace with new. It also makes it much easier to clean the sealing surfaces. Removed the aluminum plugs and oil spray bars to install new. This greatly reduces the chance of debris obstructing oil flow. These parts are 45 years old…. A couple times in the ultrasonic and then blow everything off with compressed air.
| jim_hoyland |
Mar 1 2026, 08:20 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,048 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
(IMG:style_emoticons/default/smile.gif) Interesting, keep posting..
| mepstein |
Mar 5 2026, 02:44 PM
Mahle cylinders and custom JE pistons that have been undercrowned and coated.
Attached thumbnail(s) |
| Steve |
Mar 5 2026, 04:04 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,033 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
Very nice!! What is the plans for cams and induction? Also always curious about cost?
| infraredcalvin |
Mar 5 2026, 05:31 PM
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,738 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California
Ooooh, please lots of pics and details! Those JE’s look very similar in profile and piston cut to the Mahles that just went into my burnt 3.4.
What cylinders are those/where’d you source? I have some older Mahle motorsport 98mm single plug pistons i was thinking of doing a 3.2SS… but i need to source the cylinders or have the 3.0 cylinders bored and coated??? |
| mepstein |
Mar 5 2026, 06:49 PM
Very nice!! What is the plans for cams and induction? Also always curious about cost? Cams are special. Streetable but very performance oriented. Induction will be Clewett ITB’s and Haltech efi. Cost is a core engine, parts and labor. The efi & itb’s add a significant cost over stock induction but really make it fun. A note about EFI. There’s a cost for parts but you can expect to pretty much double the cost to actually get it running and tuned. We’ll have a custom harness made, engine installed in the car and dyno tuned. I’ll post the engine to completion and then show it in the car if the buyer is ok with it. |
| mepstein |
Mar 5 2026, 06:55 PM
Hard to tell from the pics but the pistons are undercut to save a bit of weight. Pauter rods are lighter and stronger than stock. It all adds up, or in this case, adds up to less weight.
| flyer86d |
Mar 6 2026, 05:10 AM
Member ![]() ![]() Group: Members Posts: 484 Joined: 12-January 11 From: Corea, Maine Member No.: 12,585 Region Association: North East States |
I had a very similar motor in my track 911 way back when but with Weber 46’s and GE80 cams. It was a wonderful revvy engine that would light off the tires in first when it came up on its cams at 5000rpm, rev to 7500 and was very reliable. I never had it out of the car in the eight years I owned it. This will be a fun motor!
Charlie |
| 930cabman |
Mar 8 2026, 03:05 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,594 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Gonna be a rocket, keep posting as you go
| mepstein |
Mar 8 2026, 03:11 PM
Slowed down a bit while we finish a stock-ish 2.4 for a customer and work on some other stuff.
Also building an IROC car. Attached image(s)
| tailwind22 |
Mar 9 2026, 11:56 AM
Member ![]() ![]() Group: Members Posts: 96 Joined: 7-November 17 From: Moses Lake, WA Member No.: 21,583 Region Association: Pacific Northwest
Super excited that the first 3.2 SS motor is destined for my 73 GT car. Going to have Mark throw some ITBs on it with a Haltech ECU. Will be a rocket! Love the work you guys are doing on the IROC.
| mepstein |
Mar 18 2026, 07:53 AM
More engine progress. This was after cc’ing heads, cutting piston rings, etc, etc.
Waiting on cams. Attached image(s)
| mepstein |
Mar 20 2026, 08:04 PM
Not a glamour shot but progress.
My engine builder forgot that 914’s need the lover valve covers modified. We’ll do that eventually. Attached image(s)
| pete-stevers |
Mar 21 2026, 02:24 PM
Shinee Side Up Prep and Paint ![]() ![]() ![]() ![]() Group: Members Posts: 2,674 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest
THat motor looks great!! I bet it will sound as good as it looks!!!
| mepstein |
Apr 16 2026, 06:53 PM
Mocking up some parts.
Sorry, took the pick with the camera facing up. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 17th April 2026 - 09:21 AM |
