> Oil pressure switch removal tricks
TonyA
post Mar 10 2026, 04:28 PM
Nachmal
Is there a special way to remove an oil pressure switch on a 2.0. I am worried that i may drop it behind the tin.
Replies(1 - 3)
FlacaProductions
post Mar 10 2026, 05:32 PM
Interesting - I took mine out and replaced it with a hose for a remote "block" in order to use both a sender for the idiot light as well as one for a gauge. I think it's a 24mm - but I don't remember anything special to avoid dropping it behind the tin....maybe i just got lucky?
Shivers
post Mar 10 2026, 07:02 PM
QUOTE(TonyA @ Mar 10 2026, 03:28 PM) *
If I can not find my spark plug socket, I will use a strip of cardboard from the spark plug box and wedge the plug into the socket. You can remove them the same way. Just a thought
GregAmy
post Mar 10 2026, 07:44 PM
Here's my trick, but I have not used it in a while so YMMV.
Large deep socket to get it really loose, like finger-tight loose. Get a piece of rubber fuel line that will fit around the body of the electric ceramic terminal and capture it, use that to twist and remove the sensor the rest of the way.
Use that same rubber hose to reinsert the fitting (ensuring proper thread grip and not cross-threaded) then use same deep socket to tighten it.
I use the same technique with spark plugs.
6 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
1 Members: TonyA
- Lo-Fi Version Time is now: 10th March 2026 - 08:25 PM
