> Fuel pressure help, 1st start after rebuild
TonyA
post Mar 16 2026, 12:23 PM
Nachmal
Doing the first start on a stock 1974 2.0 FI
I have confirmed spark and some fuel. When i put a little gas down the intake it runs a little. My spray at #2 was weak. I had the pump wired backwards. I fixed that. I put a gauge in line after the fuel rail going to the side port of the regulator. I confirmed getting fuel from the side rail after #1 the hose at the end of the regulator goes to the return across the engine to the side return line. I am getting 42PSI. Is this the correct location for the fuel pressure gauge? Is the plumbing correct fuel rail end at #1 to side port and top end port to the return? With this configuration I tried to lower pressure and I cannot. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif)
Replies(1 - 3)
mgphoto
post Mar 16 2026, 01:07 PM
"If there is a mistake it will find me"
You should be able to reduce the pressure at the fuel pressure regulator which is at the end of the fuel ring. I think it’s 37 lbs.
TonyA
post Mar 16 2026, 01:28 PM
Nachmal
Thanks but is the plumbing correctly routed?
Ron914
post Mar 16 2026, 06:39 PM
QUOTE(TonyA @ Mar 16 2026, 01:23 PM) *
Hello ,
My supply comes in on the passenger side and feeds # 3 & 4 Cyl then crosses over to driver side fuel rail and feeds #2 & 1 Cyl then to the port on the side of fuel pressure regulator then out the bottom back to the return to tank . Fuel pressure should be around 29.3 psi . My car is a 76 2.oL D-Jet Fi
- Lo-Fi Version Time is now: 17th March 2026 - 02:32 AM
