> What oil temp / fuel gauge is this?
75ninefourteen
post Mar 16 2026, 01:16 PM
I've been trying to figure out what model this gauge was originally. So far in searching I've seen some close that are out of a 914-6, but have also seen similar marked as 911. Any ideas? I haven't had a chance to pull the gauge to look for a part number yet. I think the sensor for the oil temp is mismatched since it's reading cool.
Replies(1 - 9)
930cabman
post Mar 16 2026, 01:41 PM
I am unable to assist with the gauge, but you may consider checking the low temp reading with a known source, IR or similar
GregAmy
post Mar 16 2026, 02:10 PM
That appears to be a 1970-1972 914/6 combo gauge, per P914.com (RIP)
https://web.archive.org/web/20190718110228/...auges_combo.htm
If you tilt it back at an extreme angle you may be able to see a part number under the rim/bezel at the top.
brant
post Mar 16 2026, 03:36 PM
The gauge should have a tiny part number in it.
Seen at an angle
Looks like the 6 one which doesn’t have dash bulbs
The 4 cylinder combo gauge did have dash lighting
fixer34
post Mar 16 2026, 03:41 PM
The one on my -6 has horizontal lines in the two 'boxes'. See if you can get the part number on the upper rim.
914Wes
post Mar 16 2026, 04:09 PM
Post the part number. Attached image to show where its marked.Attached Image
914Sixer
Look in 12 o'clock position. It is a 914-6 gauge with later 911 sportmatic temp style gauge.
75ninefourteen
post Mar 16 2026, 04:19 PM
QUOTE(914Wes @ Mar 16 2026, 05:09 PM) *
Thanks for the image. I will see if I can see where its marked.
75ninefourteen
post Mar 16 2026, 04:40 PM
QUOTE(930cabman @ Mar 16 2026, 02:41 PM) *
Thanks for the suggestion. I am planning to check the temp through the oil dipstick tube as a starting point.
porschetub
post Mar 16 2026, 08:44 PM
QUOTE(75ninefourteen @ Mar 17 2026, 11:40 AM) *
Good idea should be close enough as reading is from the sump anyway pay to check the "G" wire on the gauge to sender ,most likely you have a duff sender or wrong rating for the same ,cheers
7 User(s) are reading this topic (6 Guests and 0 Anonymous Users)
1 Members: beltwerks
- Lo-Fi Version Time is now: 17th March 2026 - 02:32 AM
