| cabrioartie |
Mar 18 2026, 05:09 PM
Newbie ![]() Group: Members Posts: 22 Joined: 8-October 24 From: Las Vegas, NV Member No.: 28,400 Region Association: None
The car is a '74 2.0l, trying to fix all the items wrong after purchase.
Have found the following items bad and have replaced them: - MPS - AAR - Decel Valve - CHT - Spark plugs and wires I have a bogging/lack of power at about 3000 RPMs, I assumed it was the TPS. But, testing it with the 20 click method I get all 20 clicks consistently. My question is, is this a valid test to ensure the TPS is good? And if no, how else should I test it? And if yes, what else could be wrong to cause the problem? |
| bdstone914 |
Mar 18 2026, 05:27 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,274 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
The car is a '74 2.0l, trying to fix all the items wrong after purchase. Have found the following items bad and have replaced them: - MPS - AAR - Decel Valve - CHT - Spark plugs and wires I have a bogging/lack of power at about 3000 RPMs, I assumed it was the TPS. But, testing it with the 20 click method I get all 20 clicks consistently. My question is, is this a valid test to ensure the TPS is good? And if no, how else should I test it? And if yes, what else could be wrong to cause the problem? Pull the cover and inspect the traces on the circuit board. They can get worm. Sometins the arms can be bent to get the points to contact solid traces. |
| emerygt350 |
Mar 18 2026, 05:47 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,483 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
The clicks are a good method. If the TPS is shot you can get a complete cut at cruise or the loss of clicks. Is the bog you mention like a carb or does it feel like a complete engine wide miss?
| mgphoto |
Mar 18 2026, 07:00 PM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,418 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
The car is a '74 2.0l, trying to fix all the items wrong after purchase. Have found the following items bad and have replaced them: - MPS - AAR - Decel Valve - CHT - Spark plugs and wires I have a bogging/lack of power at about 3000 RPMs, I assumed it was the TPS. But, testing it with the 20 click method I get all 20 clicks consistently. My question is, is this a valid test to ensure the TPS is good? And if no, how else should I test it? And if yes, what else could be wrong to cause the problem? I’ve found that the bog down at 3k is a distributor issue. Swooped in a 123 problem solved. |
| cabrioartie |
Mar 18 2026, 07:59 PM
The car is a '74 2.0l, trying to fix all the items wrong after purchase. Have found the following items bad and have replaced them: - MPS - AAR - Decel Valve - CHT - Spark plugs and wires I have a bogging/lack of power at about 3000 RPMs, I assumed it was the TPS. But, testing it with the 20 click method I get all 20 clicks consistently. My question is, is this a valid test to ensure the TPS is good? And if no, how else should I test it? And if yes, what else could be wrong to cause the problem? Pull the cover and inspect the traces on the circuit board. They can get worm. Sometins the arms can be bent to get the points to contact solid traces. Can the TPS cover be removed while the TPS is in the car? What would be the procedure? |
| cabrioartie |
Mar 18 2026, 08:02 PM
The clicks are a good method. If the TPS is shot you can get a complete cut at cruise or the loss of clicks. Is the bog you mention like a carb or does it feel like a complete engine wide miss? Feels like a complete lack of power, and if I continue to push on the accelerator it eventually causes the car to jump forward/or feel like its accelerating, but it never feels like it has the proper power. |
| cabrioartie |
Mar 18 2026, 08:09 PM
The car is a '74 2.0l, trying to fix all the items wrong after purchase. Have found the following items bad and have replaced them: - MPS - AAR - Decel Valve - CHT - Spark plugs and wires I have a bogging/lack of power at about 3000 RPMs, I assumed it was the TPS. But, testing it with the 20 click method I get all 20 clicks consistently. My question is, is this a valid test to ensure the TPS is good? And if no, how else should I test it? And if yes, what else could be wrong to cause the problem? I’ve found that the bog down at 3k is a distributor issue. Swooped in a 123 problem solved. I actually purchased a 123 when I purchased the car, but I haven't thought about putting it in since I had so many other problems/failed components. I didn't want to change more than one thing at a time, but I've now replaced most of the failed items and could replace the distributor. I was waiting on the 123 install until the car was running properly just in case the install didn't go well. Then I would know what was causing the problem. |
Lo-Fi Version | Time is now: 18th March 2026 - 09:15 PM |
