| robkammer |
Mar 18 2026, 07:16 PM
Robbo ![]() ![]() Group: Members Posts: 305 Joined: 7-January 21 From: Vermilion Ohio Member No.: 25,049 Region Association: NineFourteenerVille |
All: Finishing up the LE engine bay and I’d like to refinish the intakes in a color close to original. I don’t have spraying equipment so it needs to be rattle can. I checked the local Auto parts stores VHT selections and nothing comes close Jeff B had a rec back in 2006 but I’m not sure that company sells in small cans.
Suggestions? |
| Garland |
Mar 21 2026, 06:10 AM
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,438 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest
| robkammer |
Mar 22 2026, 06:53 AM
Thanks Garland: Those do look nice! I thought I had a solution, found a paint store that will custom mix automotive paint in a rattle can. Only to find out that they need a large flat space to scan for the correct color. So, went to Sherwin and found swatches that seemed really close that they could scan. Only then I didn't know whether to use the faded runner color or the color that was under the connecting hoses. I'm liking the Ford gray. Need to keep moving.
Rob |
| TRP |
Mar 23 2026, 11:14 AM
Member ![]() ![]() Group: Members Posts: 461 Joined: 2-September 23 From: Morgan Hill, CA Member No.: 27,559 Region Association: None
Wow! Those look fantastic. I had mine powder coated and the color was much lighter than I had anticipated. The Ford Grey looks spot on.
| wonkipop |
Mar 23 2026, 11:58 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,783 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
depends how fussy you want to be.
ford grey looks ok but its quite a bit off original. original is VW L249. basically a dove grey with bluish tinge and a fair bit lighter than ford grey. see here. this is very close if not 100% correct. https://www.alanhschofield.com/ourparts/pro...erosol-Can.html |
| JeffBowlsby |
Mar 23 2026, 02:29 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,385 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
The HEs, most of the heat ducting and intake manifolds (all the same coating) are high heat conditions, the coating must resist high temps and its a matte gloss finish:
Attached thumbnail(s) Attached image(s)
| wonkipop |
Mar 23 2026, 05:09 PM
The HEs, most of the heat ducting and intake manifolds (all the same coating) are high heat conditions, the coating must resist high temps and its a matte gloss finish: (IMG:style_emoticons/default/agree.gif) def matt finish on intake runners originally. i'd have to do more research to be 100% sure but i would not mind betting the orig factory paint finish on exhaust, mufflers, heat exchangers etc was the same L249 color as the intake runners as well. maybe a different composition paint ??? but was same color i feel. |
| wonkipop |
Mar 23 2026, 05:20 PM
this could be paint formula for the dove grey.
not sure whether gloss or not. VW painted a lot of the utilitarian parts on beetles etc with the color. commercial grade kombi vans had non chromed hubcabs in this color for instance. https://www.thesamba.com/vw/forum/album_pag...p?pic_id=252702 for the fanatics out there. (IMG:style_emoticons/default/biggrin.gif) and i guess if you ( @robkammer ) are restoring an LE you probably are after the real deal color for accurate restoration purposes? couple of 74 1.8 examples. you can see the bluish tone of the orig dove grey. my car. orig. one from the files, very original low miles car. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 11th November 2026 - 06:40 AM |
