> 914World Classifieds Rules
> 1.7, and 1.8 injectors, plus Throttle body, distributor
brant
post Mar 22 2026, 08:07 AM
a single 1.7 injector that was sent out/rebuilt... unfortunately i cant find the spec sheet
40$ + shipping
Replies(1 - 6)
brant
post Mar 22 2026, 08:09 AM
1975 l-jet injectors
cores, used to run 10 years ago, stored dry
100+shipping
brant
post Mar 22 2026, 08:16 AM
L jet throttle body
no TPS
very good core
no wear edges from butterfly
50$ + shipping
brant
post Mar 22 2026, 08:23 AM
1.7 distributor with trigger points
was used as a travel spare for emergencies
very low test miles on cap/rotor/points
works well
the vacuum canister diaphram holds vacuum on the port pointing outwards, not on the port pointing in
50$ plus shipping
brant
post Mar 22 2026, 08:27 AM
oil pump plate from cludes buggies (cb)
this is for a conversion to a full flow oil set up
10$ + shipping
brant
post Mar 22 2026, 08:31 AM
track exhaust made to fit the 2.0 bursche muffler
some of the bursche's have a removeable muffler at the flange just upstream
it was an option
this bolts there, maintains the cross-over of the system center outlet.. 3 bolts
i used to drive to the track and bolt this on
i have a spare flange if your bursche doesnt
20$ + shipping
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
brant
post Jun 8 2026, 10:47 AM
make me an offer... still need to clean this crate of parts off of the bench.
brant
- Lo-Fi Version Time is now: 8th June 2026 - 02:57 PM
