| Charles Freeborn |
Mar 27 2026, 10:59 AM
Member ![]() ![]() Group: Members Posts: 345 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest |
Tap the hub out they said... It shouldn't take much force they said...
Ugh, after an hour of slide hammering with very little movement I pulled the retainer plate (not easy with hub in) and yanked the whole assembly off of the trailing arm. Then using a McGyver arrangement of gear pullers (broke one) managed to get the bearings loose from the hub stubs. Race car temps, some rust and age had them firmly stuck.... Finally going back together... ![]() ![]() ![]() ![]() Attached image(s)
| sixnotfour |
Mar 27 2026, 06:49 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,378 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
Ugh,,Glad you gotr done... On a Good Day I have a tool that pulls the Hub /Bearing without pulling the stub or axle...
(IMG:style_emoticons/default/drunk.gif) Yours is worst case scenario,, (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/sunglasses.gif) |
| Charles Freeborn |
Mar 28 2026, 02:45 PM
Ugh,,Glad you gotr done... On a Good Day I have a tool that pulls the Hub /Bearing without pulling the stub or axle... (IMG:style_emoticons/default/drunk.gif) Yours is worst case scenario,, (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/sunglasses.gif) Yeah, lucky me… judging by the look of the bearings it appears they’ve both gotten very hot in their lives. I might cut one open to have a look inside just to see for myself. |
| mepstein |
Mar 28 2026, 03:08 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,924 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Next time hit the bearing race with a torch before you pull with the bearing puller.
| Charles Freeborn |
Mar 28 2026, 05:09 PM
| Charles Freeborn |
Mar 28 2026, 05:13 PM
Lo-Fi Version | Time is now: 4th October 2026 - 10:55 PM |
