> Intake gaskets for carbs ?, single, then dual 40s
Literati914
post Mar 31 2026, 03:21 PM
Which gaskets are needed for the area @ the runners and the head, on a 1.7L w/ single carb ?
There was 8 individual metal gaskets when I removed the runners (single carb). Those may be correct I don't know, but they'll need to be replaced - I see generic type 4 gaskets in single (large) paper gaskets and these single metal ones. Does one type tend to be better than the other? - both are not needed I presume?
I'm gonna put the single carb back on for a while then move to dual 40idf after a couple months probably. Which are best for that set up, if different?
Replies(1 - 1)
porschetub
post Mar 31 2026, 11:13 PM
QUOTE(Literati914 @ Apr 1 2026, 10:21 AM) *
Those alloy gaskets are from the T4 carbed bus engines ,they are fine but one use only as they are crush gaskets ,cheers.
- Lo-Fi Version Time is now: 1st April 2026 - 01:36 AM
