Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
> 914.571.123.10, Connecting Hose - Fresh Air Blower to Control Box
DennisV
post Apr 1 2026, 05:17 AM
Blower to control box 914-571-123-10 (#15 in drawing). As of April 2026 NLA.
The OD of the tubes you connect to are ~60.25mm (2 3/8"). Hose length is 190-200mm (7 7/8"). A bit hard to measure accurately given the accordion nature of it.
The original hose from our 1970 914-6 is black paper outer with shiny foil inside. By comparison, a hose I took off a 1974 914-4 is all plastic.
Note: Porsche lists a different part number for:
Control box out 914-572-123-10 (#19).
Not to be confused with Engine Compartment Blower Hose.
Replies(1 - 1)
sixnotfour
post Apr 1 2026, 09:33 AM
early paper/foil... later plastic.. hard to find not cracked.. you can get the tan paper/foil hose which is correct for a 1970..
- Lo-Fi Version Time is now: 1st April 2026 - 08:34 PM
