> Apron to hinge bolts., vertical adjustmet.
nivekdodge
post Apr 5 2026, 07:02 PM
The bolts are stiff, so not wanting to rip out the fasteners. Do the bolts thru the hinge and into the fender apron have any adjustment to them, (IMG:style_emoticons/default/smash.gif) if I get them loose?
Kevin
Replies(1 - 2)
Ishley
post Apr 5 2026, 08:04 PM
Are you talking about door adjustments?
post Apr 5 2026, 08:22 PM
Yes, the nuts are caged but not captive. You should get about ~5mm movement from each nut. Most adjustments to the door fit can be made with a 2x4 in minutes unless there is damage at the door post. (IMG:style_emoticons/default/beerchug.gif)
- Lo-Fi Version Time is now: 6th April 2026 - 12:03 AM
