| thomasotten |
Apr 8 2026, 09:43 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,572 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
Microsquirt ECU for sale. It has a connection problem. One of the fuel injection circuits will sometimes cut out (pin 9 and 10). The problem, once identified, was resolved by simply pushing the harness in firmly. However, the problem returned. Always, it could be resolved with the simple harness push. I believe it is a bad connection, not in the harness but in the ECU (replacing the ECU solved the problem).
I have tested the pins for continuity to the backside where the soldering is, but can't find any problems. Will requires someone with patience and necessary troubleshooting and soldering skills. Or, if someone know what the likely issue is, please reply here as well. Offering as-is. $45 shipped. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 8th April 2026 - 01:30 PM |
