> Would drilling a small hole in a PORSCHE center reflector hurt it's value?, 911 OE center reflector cut down for use on a 914
914rrr
post Apr 16 2026, 07:35 AM
My 75 1.8 has a really nice but cut-down / modified 911 rear center reflector. I was fiddling with the taillights last weekend and may have disturbed the solenoid wiring for the rear trunk release. Now the button won't pop the rear trunk open.
Many years ago I had a similar set up and drilled a tiny hole in the reflector in order to insert a thin allen wrench to open the rear trunk in emergencies. Since the reflector is already cut and only useful to 914 owners, would drilling a small hole in my reflector decrease it's value? I'm contemplating removing the reflector and going back to the stock set up.
Thoughts?
Replies(1 - 9)
sb914
post Apr 16 2026, 08:04 AM
Surf Guru
I’d go back to stock . Looks better and it’s a pia when it won’t open .
post Apr 16 2026, 08:20 AM
914-6 GT in waiting
Yes but does it really matter if that’s what you need to do to get the lid open.
jd74914
post Apr 16 2026, 08:43 AM
Its alive
If you're so inclined...you can remove the trunk catch with about 3ft of extensions...they will flex enough to get you to the right place putting them on one by one from the engine bay. BTDT. Then got rid of the reflector.
914rrr
post Apr 16 2026, 09:32 AM
QUOTE(mepstein @ Apr 16 2026, 09:20 AM) *
I really don't need to drill a hole to get the lid open, but it would be easier and way more convenient for future snafus. I don't want to drill a hole in it if it substantially decreases the reflector's value / desirability to a subsequent 914 owner.
914rrr
post Apr 16 2026, 10:26 AM
rjames
post Apr 16 2026, 10:41 AM
I'm made of metal
It would likely decrease the value of it unless it's in less than good condition already.
I have a cut down reflector on mine (previous owner mod) and had the soleniod fail shortly after buying the car. I went the route of drilling a hole in the trunk floor just large enough to run a bike brake cable through to open the trunk from below. Not a perfect solution either, but works until I can remove the refelctor and patch the holes in the back panel.
Superhawk996
post Apr 16 2026, 11:03 AM
Doh
Superhawk996
post Apr 16 2026, 11:07 AM
QUOTE(Superhawk996 @ Apr 16 2026, 01:03 PM) *
QUOTE(jd74914 @ Apr 16 2026, 10:43 AM) *
(IMG:style_emoticons/default/agree.gif) this !!!
Hint: tape the extensions and the socket together so they can’t separate in the trunk
Superhawk996
post Apr 16 2026, 11:08 AM
Doh!
5 User(s) are reading this topic (3 Guests and 0 Anonymous Users)
2 Members: 914Wes, cgnj
- Lo-Fi Version Time is now: 16th April 2026 - 01:08 PM
