> Curious what you guys would expect with suspension setup
peteinjp
post Apr 19 2026, 03:32 AM
Narrow body 2.7 with 230ish hp. A052 195's on 6" wheels.
21mm hollow torsion bars in the front
Bilstein raised spindle RSR struts
Bilstien HD shocks
Tarett 22mm front bar and links
150 lb springs rear
Bilstein sport shocks
Factory rear sway bar
Patrick Motorsports adjustable tow link set for the rear
What would you expect in terms of handling with this setup? No autocross- just hard driving on mountain roads.
Pete
Replies(1 - 3)
post Apr 19 2026, 05:03 AM
914-6 GT in waiting
Pretty miserable with the 21mm bars. Even mid 80’s Carrera’s only used 19mm and they weight 500lbs more than your car. 150lb springs, sport shocks and rear sway bar will build in a lot of oversteer. If you have low profile tires, then it will be even worse. Heavily lowered car, 3x worse.
I may be wrong about everything above but I think you are building a track setup and unless your roads are velvet smooth, it will become miserable to drive on the road. It will feel really cool for about five miles but once you realize there’s almost no suspension travel, it will become a chore to drive.
What I’ve discovered for myself is these cars have a lot of “built in handling” but if you try to radically ramp up the stiffness, they loose most of their suspension travel and become rigid buckboards.
Superhawk996
post Apr 19 2026, 06:40 AM
Always hard to tell based on specs alone and I’m not in the mood to do the math but that’s a lot of wheel rate in the front end between 21mm torsion bars and a 22mm anti roll bar.
I’ll put my bet in for plenty of understeer.
post Apr 19 2026, 07:15 AM
914-6 GT in waiting
QUOTE(Superhawk996 @ Apr 19 2026, 08:40 AM) *
I agree with the understeer but there’s also a lot going on with the rear. I’m certainly no suspension expert but I do know from experience that bigger isn’t always better on these cars. They are light and nimble but become a chore if you loose too much travel.
- Lo-Fi Version Time is now: 19th April 2026 - 03:42 PM
