| Charles Freeborn |
Apr 22 2026, 03:40 PM
Member ![]() ![]() Group: Members Posts: 345 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest |
Can anyone ID this brake part? It's inline to the front brakes only. I've never seen such a thing. My pal Eric at PMB thinks it's a residual pressure regulator meant to keep some brake pressure on tap for a firmer pedal... News to me...
| stownsen914 |
Apr 27 2026, 07:06 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,032 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
That thing looks like a Safety Braker. In the 70s, people put them on sports cars and racecars. Not sure if they did much really, and it's probably old enough I wonder if it works anymore.
Found this reference: http://ftp.team.net/html/vintage-race/2005-09/msg00027.html |
| Charles Freeborn |
May 2 2026, 10:32 AM
That thing looks like a Safety Braker. In the 70s, people put them on sports cars and racecars. Not sure if they did much really, and it's probably old enough I wonder if it works anymore. Found this reference: http://ftp.team.net/html/vintage-race/2005-09/msg00027.html That tracks. Car was converted to race shortly after it was delivered new in '72(ish). It's only on the front brake circuit. Maybe over winter I'll pull it and see if it's "rebuildable". Thanks for the info. |
| sixnotfour |
May 3 2026, 03:06 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,378 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
Safety Braker... theres a couple of post somewhere .. my 1997 last raced 914 racer has em too
| sixnotfour |
May 6 2026, 08:32 AM
| sixnotfour |
May 6 2026, 08:34 AM
| sixnotfour |
May 6 2026, 08:40 AM
similar dif. manufacture .. one on each rear.. big Outlaw calipers..
https://www.73-87.com/7387garage/chassis_suspension/lbs.htm Attached thumbnail(s) |
| Charles Freeborn |
May 6 2026, 08:47 PM
There's my answer... So... anyone had one apart? Is it A.) worth keeping and B.) rebuildable / serviceable?
Thx! |
| sixnotfour |
May 18 2026, 12:56 PM
Garretson Enterprises 1977
| jd74914 |
May 19 2026, 09:12 AM
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,890 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Interesting...
Can someone explain to me what it is? The links make it seem like a hydraulic pulsation damper? Is that true? |
| GregAmy |
May 20 2026, 06:39 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,701 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
It's basically an air-assisted pressure damper/accumulator, used to dampen the pulses of a non-perfectly-flat rotor. It's really a bit of old technology and, if I may offer, a bit toward the "tornado intake twister for better fuel economy" JC Whitney sorta thing. I suggest it will give you a much more nebulous pedal (which you can do on your own...)
The general concept is useful but I find the declaration that "I have never had a wheel lock up under braking with them on the cars" to be a bit...specious. Simply my opinion, of course. I found this old article on how the general idea works, technically, when installed on larger trucks and RVs: https://web.archive.org/web/20060317215937/...arts/bguard.htm |
| Charles Freeborn |
May 20 2026, 10:22 AM
Properly mated with a synchronized flux capacitor one's performance could be... well... stellar...
This whole brake project of mine was kicked off because of a soft brake pedal, which I attributed to an undersized MC (19mm) and the big brakes it wears. Maybe this was contributing too. It is, after all, over 40 years old (closer to 50), so whatever is going on in there is likely crusty. Now is the time to either rebuild it or pull it out altogether. Film at 11. PS, The company got itself into substantial hot water with the FTC over its claims of improved brake performance.... sigh... but I do still think those JC Whitney spark plugs made my go-kart go faster.. |
| GregAmy |
May 20 2026, 12:52 PM
This whole brake project of mine was kicked off because of a soft brake pedal...Maybe this was contributing too. Well, if the device is functioning as designed, then it actually is adding compressible air to the hydraulic braking system -- separated by a diaphragm. But if it has failed internally then it's possible that there's air trapped inside it that's un-bleed-able. If it were me, I'd remove it entirely. |
| Ninja |
May 20 2026, 01:37 PM
Member ![]() ![]() Group: Members Posts: 323 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
It's basically an air-assisted pressure damper/accumulator, used to dampen the pulses of a non-perfectly-flat rotor. It's really a bit of old technology and, if I may offer, a bit toward the "tornado intake twister for better fuel economy" JC Whitney sorta thing. I suggest it will give you a much more nebulous pedal (which you can do on your own...) That is the best description of one of those I've ever read! (IMG:style_emoticons/default/first.gif) Love the "Tornado" comment. (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) I wouldn't leave that puppy on anything, especially my sports car! |
| Charles Freeborn |
May 21 2026, 08:32 AM
This whole brake project of mine was kicked off because of a soft brake pedal...Maybe this was contributing too. Well, if the device is functioning as designed, then it actually is adding compressible air to the hydraulic braking system -- separated by a diaphragm. But if it has failed internally then it's possible that there's air trapped inside it that's un-bleed-able. If it were me, I'd remove it entirely. (IMG:style_emoticons/default/thumb3d.gif) My current thought too. |
| Charles Freeborn |
May 22 2026, 03:58 PM
Here's the 411 on the "SafetyBraker"
Inside the housing is a piston that's pushed by brake fluid pressure. It bears down on a rubber gizmo, which in the case of mine is hard as a rock. There's an o-ring which I assume is meant to keep brake fluid only on the wet side of the piston. I guess there's air around the rubber plug thing, but really the resistance / dampening is done by the rubber plug. BTW, the o-ring on mine has been leaking so the rubber plug side of things was also wet. There you have it. Analog ABS at it's finest... needless to say I'm removing it... PS... for sale... guaranteed to do either something amazing or nothing at all. No lo-ballers - I know what I've got... |
| Ninja |
May 22 2026, 04:37 PM
Thanks for the autopsy and the comments...
This thread has made me laugh my ass off a couple of times now! You should make a for sale add anyways. Apply some more of that humor please! |
| GregAmy |
May 23 2026, 06:05 AM
Fantastic! I've never seen the inside of those...interesting that the opposition on yours is basically a rubber shock bump stop.
I mean, it wasn't a hateful idea in context but, well... |
| Charles Freeborn |
May 24 2026, 09:12 AM
Fantastic! I've never seen the inside of those...interesting that the opposition on yours is basically a rubber shock bump stop. I mean, it wasn't a hateful idea in context but, well... There is some logic to the idea. I'm not sure if the "one size fits all" rubber bumper gives any tuneability to it, but I'm likely overthinking... again... |
Lo-Fi Version | Time is now: 4th October 2026 - 10:55 PM |
