| Wew |
Apr 23 2026, 08:57 AM
Member ![]() ![]() Group: Members Posts: 238 Joined: 17-January 15 From: Novato, ca Member No.: 18,335 Region Association: None |
Hi all,
I have been reading many posts and doing lots of research and am throwing in the towel and putting this out to the brain trust. I rebuilt the transmission (Dr evil CD) and new clutch flywheel throw out bearing etc. Swepco transmission fluid. Shifting has always felt kind of stiff. After many shifter alignment issues and clutch adjustments, Checking to make sure clutch cable is not twisted around accelerator cable or a broken guide tube as I drove car I would notice it was much harder getting into 1st and reverse. So I tinkered again adjusted clutch cable and alignment. Now I can’t get reverse at all. Here’s the thing I notice with the clutch fork, it barely moves when tension is removed from clutch cable. It takes serious effort to move it by hand 1/8-1/4”. The car has sat for a while as I was sorting through other problems and other projects. For giggles I readjusted the shifter with a bias towards drivers side and still can’t get it into reverse. Is this clutch drag? If so what is the remedy other than dropping the transmission and redoing the clutch fork and throw out bearing. Thank you all for reading this long winded message and weighing in. |
| mgphoto |
Apr 23 2026, 09:20 AM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,445 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Did you resurface the flywheel, if so you should have added an additional washer under the fork pivot to compensate for the fork hitting the tranny case.
You don’t mention tail or side shifter? |
| Wew |
Apr 23 2026, 09:24 AM
Thank you for the response. Flywheel is brand new and it’s a side shifter.
Thank you for responding. |
Lo-Fi Version | Time is now: 23rd April 2026 - 12:26 PM |
