| 914rrr |
Apr 28 2026, 10:46 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,131 Joined: 1-July 03 From: McMinnville, TN Member No.: 874 Region Association: South East States |
| Krieger |
Apr 29 2026, 12:05 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,899 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
It's called a battery block positive terminal. At least that is what 914 Rubber calls it on their website. Idk if its available wnywhere else.
| Dlee6205 |
Apr 29 2026, 05:58 AM
Member ![]() ![]() Group: Members Posts: 103 Joined: 9-December 22 From: Burnsville, NC Member No.: 27,017 Region Association: South East States |
I hate those aftermarket battery terminals that clamp down on the cable.
This is my typical “aftermarket” solution. I change the connection block out for 1 with a stud. I put a ring terminal on the main battery cable going to the starter, and replace the connections on the red wires with insulted heat shrink connectors. In this case I also upgraded the cable going to the starter. |
| Chad911sc |
Apr 29 2026, 06:31 AM
Member ![]() ![]() Group: Members Posts: 328 Joined: 24-September 24 From: Florida Member No.: 28,374 Region Association: South East States |
I went with these that I purchased from Amazon. Clean and tidy, well built. Just put the wires into the slots and use Allen wrench to lock in, no connectors to mess with. I think they were like 15 bucks if I remember correctly.
Attached thumbnail(s) |
| burton73 |
Apr 29 2026, 10:43 AM
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 4,106 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California
Battery hook up PMB way
Best Bob B ![]() |
| mjrrti |
Apr 29 2026, 10:25 PM
High Desert Member ![]() ![]() Group: Members Posts: 70 Joined: 4-February 14 From: Apple Valley, Ca Member No.: 16,959 Region Association: Southern California |
I have a sloppy DAPO red positive wires and cheapo aftermarket positive battery terminal situation and would appreciate best solution to tidy these up, make better connections, etc. This also makes me curious about how 4-6 wires were originally run to the positive battery terminal from the factory. I used an automotive bus bar that I found on Amazon for around $10 on my Subaru conversion that has even more 10 ga wires that need to connect to my battery. |
| barefoot |
Apr 30 2026, 06:06 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,569 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
I took a different approach by installing a 1 in/4 out fuze block .
Now I sleep well at night (IMG:style_emoticons/default/rolleyes.gif) Barefoot ![]() |
| TRP |
Apr 30 2026, 08:07 AM
Member ![]() ![]() Group: Members Posts: 461 Joined: 2-September 23 From: Morgan Hill, CA Member No.: 27,559 Region Association: None
| FlacaProductions |
Apr 30 2026, 09:03 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,295 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
I did what @barefoot did - but mine is mounted a bit differently. Same effect.
| Root_Werks |
Apr 30 2026, 09:12 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,089 Joined: 25-May 04 From: About 15NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
If I remember correctly, the factory connected wires in pairs to a simple loop terminal that was screwed onto a block similar to what was shown earlier. Even from the factory, not the most elegant solution.
| TRP |
Apr 30 2026, 10:03 AM
I agree with @Root_Werks, not the most elegant solution. From memory on my 1.8 L-Jet car (which may be wrong) - there are three ring terminals that connect to the block. Two pairs of wires (4 total) connected to two ring terminals from the main harness, with single wire / ring terminal coming from the ignition harness.
A few of the examples shown above represent a cleaner and safe approach to the same issue. |
| anderssj |
Apr 30 2026, 10:09 AM
Dog is my copilot... ![]() ![]() ![]() Group: Members Posts: 1,807 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region
| burton73 |
Apr 30 2026, 02:40 PM
One more shot of the clean way PMB did this
Best Bob B ![]() |
| Artfrombama |
Apr 30 2026, 06:33 PM
Artfrombama ![]() ![]() Group: Members Posts: 496 Joined: 21-January 24 From: One of the chosen few Member No.: 27,870 Region Association: South East States
| 914rrr |
May 1 2026, 03:43 PM
![]() Q; how did the factory mount those 2 ring terminals to the square block + stud? Hard to tell from the pic. Also, did the factory simply crush 2 wires together in one ring terminal or did they put solder on them before crimping, or simply solder the 2 wires to the ring terminal? |
| 914rrr |
May 1 2026, 03:50 PM
| 914rrr |
May 1 2026, 03:58 PM
This pic brings up another question.
The OG 4 red wires go into the harness bundle, correct? Then why do I have 6 wires going to my positive terminal? I think one of the additional wires goes to the FI dual relay. Is power to the FI dual relay supposed to come from someplace else, like the engine bay relay board / plate? The other is power for the trunk solenoid, I think. |
| 930cabman |
May 1 2026, 05:59 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,881 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
If I remember correctly, the factory connected wires in pairs to a simple loop terminal that was screwed onto a block similar to what was shown earlier. Even from the factory, not the most elegant solution. (IMG:style_emoticons/default/agree.gif) somewhat of a "Rube" from the factory, but if maintained they work ok |
| JeffBowlsby |
May 2 2026, 07:18 AM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,385 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
At the battery:
70-72 914s had 3 red wires 73-74 914s had 4 red wires |
| wonkipop |
May 4 2026, 04:03 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,783 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
i sorted this out on mine a couple of months ago with something that kind of simulated the original set up. 1.8 L jet. might try and take some photos to post tomorrow.
Lo-Fi Version | Time is now: 11th November 2026 - 06:48 AM |
