> What is this hole?
cabrioartie
post May 1 2026, 07:45 PM
Hi,
Recently acquired '74 2.0l, I have finally gotten the engine running properly and I'm now moving on to the many other things which need to be fixed.
So, after following the site for a while, I can say, I've never seen a hole like this on anyone's car. Any guesses as to why or what it was used for?
Thanks
Replies(1 - 5)
bkrantz
post May 1 2026, 07:58 PM
Doo you mean the small hole in the shelf next to the snorkel? I would guess somebody wanted to run a wire and they did the second most easy thing (after just snaking the wire past the engine shelf rubber).
cabrioartie
post May 1 2026, 08:05 PM
QUOTE(bkrantz @ May 1 2026, 06:58 PM) *
Yes, that's the one I'm asking about.
Should I do anything about this hole? Or just leave it the way it is, or seal it up?
dtmehall
post May 1 2026, 08:28 PM
are your sure that it's just not this?
Plastic Fastener 914 Engine Insulation Padding Clip
dtmehall
post May 1 2026, 08:36 PM
maybe a replacement from a FLAPS?
TRP
post May 1 2026, 09:42 PM
I checked my 75 / 1.8 and it does not have that hole. Below that hole, or around there is the rear brake bias valve.
You could put a plastic rivet (panel plug/whatever) in there. My guess is DAPO drilled a hole for a wire or something.
Ted
5 User(s) are reading this topic (3 Guests and 0 Anonymous Users)
2 Members: PlantMan, 808 WRX
- Lo-Fi Version Time is now: 1st May 2026 - 10:49 PM
