> Can’t Find 4th/5th + Shift Linkage Issue (Helicoil Failure)
jacktarnold
post May 3 2026, 01:20 PM
Hi all,
Looking for some guidance before I go too far down the rabbit hole.
I’ve got a 1973 914 2.0 that I’m bringing back after about 10 years off the road. I’ve gone through the fuel system and brakes, got it running, and took it out for a short test drive.
Issue: I could never find 4th or 5th gear.
I started working through the shift linkage by checking bushings and alignment and found that the rear shift rod retaining screw appears to have been previously repaired with a Helicoil. Unfortunately, that insert is now backing out, so the connection isn’t solid.
Before I start tearing deeper into it, I’m trying to figure out the best path forward:
* Is it worth redoing the Helicoil, or should I go another route?
* Any preferred repair methods for this specific location that hold up long-term?
Appreciate any advice or lessons learned
Replies(1 - 4)
Jack Standz
post May 3 2026, 02:41 PM
New couplers are pretty expensive, so you could put a "wanted to buy" add here for a used one?
Not sure if it's worth trying to weld it up and cut new threads, unless you have the equipment and skill. Good luck. (IMG:style_emoticons/default/biggrin.gif)
Shivers
post May 3 2026, 02:56 PM
QUOTE(jacktarnold @ May 3 2026, 12:20 PM) *
Hi all,
a time sert would be the fix in my opinion. It really is better than the spring. https://www.timesert.com/
FlacaProductions
post May 3 2026, 03:00 PM
Put a WTB up - I'm sure someone has one - or someone here on this thread will speak up.
930cabman
post May 3 2026, 03:03 PM
I would consider this: https://tangerineracing.com/shop/ols/produc...-alignment-tool
anything from Tangerine is top shelf
Great bring another from a slumber
5 User(s) are reading this topic (3 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 3rd May 2026 - 03:37 PM
