Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
> 901.107.679.10, Sealing Ring
DennisV
post May 28 2026, 04:34 AM
Installed around threaded tube fitting for oil hose pressure line, inside fender well between oil tank body and sheet metal.
OD: 45 mm
Thickness: 4 mm
#78 in parts catalog.
NOS photo courtesy of @Kreiger
Replies(1 - 1)
DennisV
post May 28 2026, 11:37 AM
In lieu of better options, the closest thing I could find at local auto parts or hardware stores was this. ID and thickness are pretty close. OD I trimmed with some shop scissors. Found at Ace Hardware plumbing aisle.
- Lo-Fi Version Time is now: 29th May 2026 - 11:40 AM
