> Smoke show, Smoke machine results and a question
Quinn Moore
post May 28 2026, 04:20 PM
Qmoore
'73 2.0 FI stock motor.
Has been running great. Until it wasn't. Idle issues, couldn't get it really dialed in.
Running a little rough, idling around 1100. Not bad, but was rock solid at 950 rpm and smooth running (123 distributor) .
Anyway, fast forward. Hooked up a smoke machine, found injector seal on #3 leaking. Ill replace.
also noticed smoke (from the smoke machine) coming out of
The butterfly valve (plate) rod ends. A tiny bit on the TPS side, and a little more on the other side. Not much, a little.
Finally the question: Is that normal, serviceable, negligible?
(The pictue of the TPS side, couldn't capture the smoke with my phone)
Thanks for your input.
QM
Replies(1 - 1)
emerygt350
post May 29 2026, 06:54 AM
A leak is just going to increase the idle, not cause instability. That sounds more like a sensor issue. Have you got an air fuel gauge on it?
3 User(s) are reading this topic (2 Guests and 0 Anonymous Users)
1 Members: sdthomas
- Lo-Fi Version Time is now: 29th May 2026 - 10:10 AM
