| Franz_x |
May 31 2026, 06:05 AM
Newbie ![]() Group: Members Posts: 8 Joined: 12-November 22 From: Germany - Munich Member No.: 26,984 Region Association: None |
Hello from Germany,
my 2056 engine is running with the original camshaft, D-Jetronic, J&E pistons and 123ignition tune+bluetooth. I've increased the fuel pressure to 2.3 bar. I now want to install an AEM X-Series Wideband UEGO AFR Gauge Kit. Where is the best place for the sensor on the original banana exhaust? Looking at the pictures and posts, I would place it on the far right. Does anyone have experience with this? http://www.914world.com/bbs2/index.php?sho...=347120&hl= http://www.914world.com/bbs2/index.php?sho...=196079&hl= Thanks, Franz |
| emerygt350 |
May 31 2026, 06:24 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,599 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I put mine on the outer #4 pipe heading into the muffler body. This only gives me #4 signals obviously, but it worked and was easily accessible. I justified it by telling myself getting the average of all cylinders could hide problems just as easily as only seeing #1 cylinder....
My ansa style hits both 3 and 4. I will be interested in hearing how your fuel pressure fix worked out across the various cruising conditions once you get the afr installed. Make sure you post the results. |
Lo-Fi Version | Time is now: 31st May 2026 - 08:45 AM |
