> Convert back to D Jet Fuel Injection-, MPS electric issues
young55961
post Jun 8 2026, 09:42 AM
Hi there,
I purchased a D jet kit a few years back thinking convert my dual carb back to fuel injection.
I begin to inspect the parts I received.
First the MPS.
1. Pressure is good holding at 15 PSI
2. Outer Terminal(7, 15) : 94
3. Inner Terminal(8, 10) : "OL".
What does the outer and inner terminal control ?
Can it be fix ?
Tks.
Replies(1 - 1)
JeffBowlsby
post Jun 8 2026, 11:11 AM
15 PSI is probably OK if it remains steady. A steady 18 PSI is recommended.
The inner two and outer two terminals are contacts for the two coils. You should see a resistance between the outer two terminals of around ~350 ohms. If not, the problem could simply be a bad internal coil connection or the coil may be defective. The back half of the MPS can be exchanged with a known good part, requires disassembly. I may have one to swap, but you will need to send me the MPS for the repair or swap.
6 User(s) are reading this topic (4 Guests and 0 Anonymous Users)
2 Members: cabrioartie, brant
- Lo-Fi Version Time is now: 8th June 2026 - 12:24 PM
