| mskala |
Jun 11 2026, 04:05 PM
R ![]() ![]() ![]() Group: Members Posts: 1,950 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None
My car used to leak oil from lots of places. After rebuild, now everything's pretty
good. But, particularly from under the oil tank area, oil has got on a large area under the floor and longs. I found accidentally that the CRC Electronic Cleaner doesn't seem to remove paint, but it is so weak that the black undercoat (wurth?) turns into a huge amount of black goo that hasn't really come off the car. I want to save any paint and the white-ish undercoat. Any products that will do this? I assume my paint is the old lacquer type paint. Thanks Mark S. |
| 930cabman |
Jun 11 2026, 05:03 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,701 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
I would start with Dawn and work up from there.
| mark04usa |
Jun 11 2026, 05:08 PM
'70 1.7 Tangerine ![]() ![]() Group: Members Posts: 364 Joined: 14-September 09 From: Austin TX Member No.: 10,805 Region Association: Southwest Region
Next, I would try naptha it should not affect paint...try on test area first. Naptha (lighter fluid) is highly flammable and you would need ventilation.
| Cairo94507 |
Jun 11 2026, 05:15 PM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,669 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
I use BrakeKleen (the one not sold in CA) and it cleans stuff off easily without hurting or dulling the paint. I never would have guessed it but my buddy Greg has been using that on his cars for years w/no issues on any painted surfaces. As always, if you try this, try it on a spot that you can risk it on.
When we installed my rear glass, we used urethane - what a mess that was because we cut the tip of the tube off so the hole was too big. (IMG:style_emoticons/default/wacko.gif) But it all cleaned up nicely using BrakeKleen on microfiber towels. (IMG:style_emoticons/default/smile.gif) |
| JeffBowlsby |
Jun 11 2026, 05:16 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,268 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
If its oil-based, paint thinner (mineral spirits) should work and not affect cured paint.
| 930cabman |
Jun 11 2026, 06:01 PM
Simple Green
Lo-Fi Version | Time is now: 11th June 2026 - 07:02 PM |
