| detective_snakes |
Jun 12 2026, 02:36 AM
Newbie ![]() Group: Members Posts: 12 Joined: 1-September 24 From: San Fernando Valley Member No.: 28,323 Region Association: Southern California |
Hello! Yes yes! I've at least somewhat fixed the problem the mechanic handed me. I replaced the carburetor that was spitting fuel everywhere, cleaned up the battery terminals, and it starts! However, I'm back again to the issue where it doesn't idle for very long. I got it to idle a hell of a lot longer than the mechanic did, which is nice, but it still does die. So, up until now, I've...
- cleaned the fuel tank - installed new fuel hoses (rubber, not the metal ones) - installed a new rotary fuel pump + filter - cleaned the hose junction - balanced the carbs, tuned them to something that *should* at least work (zeroed, 1+1/2 turns out, 1/4 turn back in) - installed new carburetor/manifold gaskets The left carb still 'burps' sometimes and spews some white smoke. I suspect that I need to adjust the timing. In the meantime, do you figure I should try different distributor cables, a new head temp sensor...? I can't really think of many parts this could be. I already replaced the distributor as is, plus the ignition coil and a few wires. Also, I'm sure it's fine, but only one carb is hooked up to the dizzy for vacuum. The other one I can just leave open? Again, a massive thank you to everyone who helps. You are lifesavers. |
| detective_snakes |
Jun 12 2026, 02:38 AM
I should mention that I'm pretty confident that this isn't a deeper engine issue. The first time I got it back from the mechanic to clean out the fuel tank, it actually did run perfectly fine. Idled and all. We only had to take it back to re-clear the fuel lines because a bit of gunk got stuck in the metal tubes. But it never really worked again after his second round of work. I don't think it's a compression problem or anything.
Lo-Fi Version | Time is now: 12th June 2026 - 07:39 AM |
