| young55961 |
Jun 19 2026, 01:32 PM
Newbie ![]() Group: Members Posts: 34 Joined: 15-March 18 From: Arcadia Member No.: 21,972 Region Association: Southern California |
I set the engine to TDC on cylinder #1. The timing mark is lined up with the case split. Both the intake and exhaust rocker arms have a little movement when I turn the fan pulley slightly left and right.
The distributor rotor is pointing to about the 8 o'clock position. Does this look correct? Also, how do I set the static ignition timing on this engine? ![]() |
| Artfrombama |
Jun 19 2026, 02:38 PM
Artfrombama ![]() ![]() Group: Members Posts: 460 Joined: 21-January 24 From: One of the chosen few Member No.: 27,870 Region Association: South East States
I set the engine to TDC on cylinder #1. The timing mark is lined up with the case split. Both the intake and exhaust rocker arms have a little movement when I turn the fan pulley slightly left and right. The distributor rotor is pointing to about the 8 o'clock position. Does this look correct? Also, how do I set the static ignition timing on this engine? ![]() Both cyl. #1 valves should be closed to be on TDC compression, otherwise the engine is on TDC exhaust stroke I use a continuity tester to set static timing. Align your timing marks and slowly turn the distributor until the points break (no continuity) |
| Jack Standz |
Jun 19 2026, 03:30 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 843 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
If the #1 intake and #1exhaust rocker arms are moving at/around "TDC", you are not at TDC for the #1 cylinder's compression stroke.
You could be at TDC for the #1 cylinder but you may be on the exhaust stroke, but maybe not. Reconfirm everything. Things like the fan marking for TDC (some Type IV motors don't have a mark on the fan for TDC), where the distributor is installed, etc. |
| young55961 |
Jun 19 2026, 04:52 PM
If the #1 intake and #1exhaust rocker arms are moving at/around "TDC", you are not at TDC for the #1 cylinder's compression stroke. You could be at TDC for the #1 cylinder but you may be on the exhaust stroke, but maybe not. Reconfirm everything. Things like the fan marking for TDC (some Type IV motors don't have a mark on the fan for TDC), where the distributor is installed, etc. I checked both the fan and the flywheel, and all the timing marks line up. I rotated the engine one full revolution, and now the rotor is pointing to the 2 o'clock position. The problem is that the air temperature sensor is blocking distributor vac. I have to remove the sensor; otherwise, I can't set the timing. ![]() |
Lo-Fi Version | Time is now: 19th June 2026 - 05:00 PM |
