> Engine harness question- heater fan power
roundtwo
post Jun 19 2026, 04:52 PM
Hello,
Swapping out the 2.0 l engine in my 1971 for another 2.0 l ...Has lower miles (35k) and documented build.
Both engines carbed
I see the engine harness in a bit different at the end that connects to fan blower.
Pic 1 is the from the existing engine that had the fan blower mounted. Has the two wire connector to plug into the fan plug...
Pic 2 is from the replacement engine. I only see a white wire that is spare. Could this be the fan power and then I use a common ground? In understand what the other wires in the pic connect to.
Thanks the help going forward
pic 1
pic 2
car
Replies(1 - 4)
JeffBowlsby
post Jun 19 2026, 05:14 PM
Use the ignition harness in Pic 1 on your 1971 car, its correct for your set-up, with the fan mounted to the engine. The Pic 2 harness is for 1973-76 cars with the heater fan mounted to a stand on chassis.
JeffBowlsby
roundtwo
post Jun 19 2026, 08:07 PM
@JeffBowlsby
I knew you would know and was hoping you weren't on vacation!!!
Thanks Jeff
Assume all I have to do is disconnect both from the alternators?
JeffBowlsby
post Jun 19 2026, 08:56 PM
Alternator? The ignition harness connects to the relay board, not the Alternator.
You can find diagrams of the two harnesses on my harness website.
13 User(s) are reading this topic (11 Guests and 0 Anonymous Users)
2 Members: dtmehall, cabrioartie
- Lo-Fi Version Time is now: 19th June 2026 - 09:08 PM
