> Quoted $2.4k for injectors, Wondering if there is a better way
zaballosc
post Jul 8 2026, 07:38 PM
Hi all!
Been having a no-start issue, and had my car taken to a well-regarded 914 shop. They informed us that their policy is that they only use brand-new parts that they source themselves.
Outside of the no-start issue, it appears that the NOS fuel injectors that we had put on it are leaking, alongside the short hoses leading to them. We just replaced the whole fuel system with Tangerine Racing stainless lines with new rubber.
They said that the tiny rubber lines are backordered, and the injectors run about $500 per. I'm confused, as I see hundreds of listings for part FJ67 for $120 online. Am I missing something here?
Let me know if i am overreacting.
Replies(1 - 19)
Superhawk996
post Jul 8 2026, 07:43 PM
Find a new shop that isn’t intent on scamming you.
PS - send your injectors to Mr Injector. He will test & clean them. If they are truly leaking and aren’t worth cleaning he will not charge for them.
bkrantz
post Jul 8 2026, 08:12 PM
QUOTE(Superhawk996 @ Jul 8 2026, 07:43 PM) *
Yup.
JamesM
post Jul 8 2026, 11:23 PM
wow....
Actual cost on FJ67s is less than 100 bucks a piece.
500 if they were talking the whole set maybe.
Shops only installing parts they source is not uncommon, but those prices are out there.
I don't have the factory book in front of me at this exact moment but I know even factory book time to replace 4 injectors was less than 2 hours.
The elbows are an absolute non issue, even if you don't know 914s.
Worst case replacing all the fuel lines in the engine bay at the same time with good German braded stuff you are still under 1000 bucks.
emerygt350
post Jul 9 2026, 04:08 AM
And a no start condition from leaking injectors? Maybe a bad start. The fj67 are great
Even Mr injector thinks they are a fine replacement.
post Jul 9 2026, 04:57 AM
914-6 GT in waiting
I've had Bill at Mr Injector service hundreds of injectors for me. For what he charges, it's worth getting done if only for spares.
There are shops that charge big money for normal stuff and people open their wallets. That's fine if you have a big wallet and are ok with their work.
There is a lot of stuff on our cars, like changing injectors, that can be done with very basic tools in very little time. I'm certainly no tech but I've changed out injectors and it was easy.
Smart move going with the Tangerine products.
No start issues are usually something simple. Air, fuel spark.
GregAmy
post Jul 9 2026, 05:46 AM
QUOTE(bkrantz @ Jul 8 2026, 09:12 PM) *
Yup.
Yup.
rick 918-S
post Jul 9 2026, 06:19 AM
Hey nice rack! -Celette
Is it possible you misunderstood the per injector quote? Is it in writing? Strange.
DC_neun_vierzehn
post Jul 9 2026, 11:10 AM
QUOTE(zaballosc @ Jul 8 2026, 07:38 PM) *
Hi all!
I recently went through replacing all 4 injectors, the 4 injector rubber elbows (which I believe is what you’re referring to as “short hoses”), and all rubber lines in engine compartment.
I had never done this work on any car including my 914. The FJ67s were about $125 each. The spool of correct high pressure fuel injection Barricade line was less than $100. While the 914 FI elbows are “out of stock” in most 914 online parts vendors there is an easy, inexpensive solution. Click on my profile name and search “member’s topics” to get those details and links. You can get 4 injector elbows for less than $20.
Total time to install everything (with proper FI clamps) for a novice like me was about 4 hours. Someone who’s done it before, probably half that or less. Total amount spent for everything above less than $600 months total.
Thus, that shop is trying to rob you blind.
As others have suggested, send your injectors to Mr. Injectors for inspection, analysis, cleaning. Then go from there. I would find a 914 member near you to put the injectors and elbows on for the price of a case of beer or a nice bottle of wine. Plenty of fine folks here willing to help. I would help if you were near me.
emerygt350
post Jul 9 2026, 12:29 PM
Not sure why people are saying the elbows are not available. These are the injectors that have been on my car for 5 years without a problem.
https://a.co/d/0ewGMaEj
windforfun
post Jul 9 2026, 03:13 PM
2.4 K$ is rediculous. Shop around dude. They're actually pretty easy to replace. Just don't smoke while you're doing it.
Osnabruck914
post Jul 9 2026, 05:27 PM
Going to a "professional" shop is the absolute last resort for doing anything on our cars. I was recently quoted $1,500.00 for a rear wheel only alignment and they were going to do it via the "string and jack stand" method. Took it home and did it myself for nothing- results 'perfect'.
Osnabruck914
worn
post Jul 9 2026, 05:41 PM
QUOTE(zaballosc @ Jul 8 2026, 06:38 PM) *
Hi all!
They only use brand new parts that they source would sound better if the injectors were the problem. Not at that price of course. But I don’t see why they want to replace the injectors rather than fixing your car.
post Jul 9 2026, 06:24 PM
914-6 GT in waiting
QUOTE(zaballosc @ Jul 8 2026, 09:38 PM) *
Hi all!
I don’t know if my shop is well regarded but I wish that new parts were a guarantee of success. Unfortunately, it just means they are clean and shiny. There isn’t one new part that we buy for these engines that hasn’t come mis-sized, defective, broken or just wrong. Sometimes an original refurbished or restored part is the only acceptable solution.
For example: we don’t use uro head temperature sensors because they suck. They cost about $100. We use real Porsche branded head temp sensors. They are around $300. So my tech installs one yesterday and it was working for a bit and then doesn’t. We know it’s the new sensor because when he installs a good used sensor, the car runs right.
Sometimes throwing new parts at the problem isn’t the solution. Air, fuel and spark make the engine run.
zaballosc
post Jul 10 2026, 07:06 PM
Hey all! Thank you all for the advice. A 914 world member is picking up the car and will be swapping in a spare distributor and FI setup.
Dodged a bullet - they tried to get us to swap to carbs TWICE!
wonkipop
post Jul 11 2026, 12:00 AM
QUOTE(zaballosc @ Jul 10 2026, 07:06 PM) *
you sure did. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif)
i picked up a set of NOS injectors about 5 or 6 years ago for my L jet.
which are co-incidently shared with the beetle of slightly later.
i got them off a guy in arizona who had them in his cupboard sitting there for his beetle cab he no longer had.
60 USD each.
the key was the injectors need to be still sealed in their plastic bag.
which they were. and still in their boxes as a bonus.
worked beautifully.
helped he had stored them in a dark cupboard.
but unless still sealed in plastic bag, NOS means nothing.
still work beautifully.
not sure what your mechanics were up to but it sure sounded like up to no good.
Jack Standz
post Jul 11 2026, 09:54 AM
QUOTE(zaballosc @ Jul 11 2026, 08:06 AM) *
This is the way. (IMG:style_emoticons/default/biggrin.gif)
ctc911ctc
post Jul 11 2026, 08:23 PM
Rock Auto shows them for 43 and 100 - depending on core? Still, you can do pretty well with just a few clicks. Also, I did the ORIGINAL and sent to Hurst-Injectors in Worchester MA, works great since I got them back!
TheCabinetmaker
post Jul 12 2026, 08:51 AM
I drive my car everyday
QUOTE(JamesM @ Jul 9 2026, 12:23 AM) *
wow....
James, I've had several cars with the braided hoses seeping gas thru the cloth braid after the inside rubber deteriorated from ethanol gas. I stopped using it many years ago.
sithot
post Sep 14 2026, 01:09 PM
I bought a set of 4 FJ67's a few years ago when an original hose gave up and started leaking.
Replaced the one without looking at the other 3 I ordered. My mistake. I ended up with 2 having a straight run hose and one with the "90 degree" hose.
Recently, I'd been seeking some "busy work" and I started only to find my plans were sabotaged.
I called to Bill and he asked me about the color of the bodies. I told him two were black and one was shiny at the business end. All the numbers on the injectors were identical, but the boxes were different. He was curious as was I but neither of us had a good answer. He did offer some advice for using what I have by using a spring inside the bore of the hose allowing it to bend without kinking.
Why didn't I think of that? (IMG:style_emoticons/default/headbang.gif)
I highly recommend using Bill Johnson/Mr. Injector for your work. Very enjoyable to chat with and knows his stuff.
7 User(s) are reading this topic (3 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 14th September 2026 - 01:56 PM
